Radiator
Old Feb 2, 2003 | 08:58 PM
albertafarmer's Avatar
albertafarmer
Radiator
Any pros or cons on cross flow radiators over down flow. I am installing a 460 engine in a 79 F-350 out of a 75 Merc station wagon. The station wagon had a cross flow radiator, but the F-series trucks only used down flow. Which one should I use?
Old Feb 25, 2003 | 11:25 PM
thoseapples's Avatar
thoseapples
Radiator
The cross-flow design is more efficient, based on what I've read. The coolant can't flow straight down in them, it must migrate through each core tube between the side tanks. Guess it promotes full use of the surface area of the fins and cores on the outside whereas the vertical versions might allow stagnant cold spots in the corners or outermost cores. A vertical flow shouldn't hurt you a bit, though. If you're just putting together something stock for beating around in or whatever, you could get away with either, I'd imagine.
69issofine
Sep 4, 2014 11:18 AM
CharlieLed
Jun 8, 2007 06:34 AM
AmeriKen
13
Jul 26, 2005 09:29 PM
DPW
Apr 17, 2003 12:35 PM
itlkick
16
May 22, 2002 04:05 PM
