IPR HELP!!
Old May 20, 2010 | 10:04 PM
AXE168's Avatar
AXE168
IPR HELP!!
Hey guys, I just changed the IPR on my 95 F-350 and after a day of running the way it should I have a check engine light again, and its showing a code for the IPR. I went back in and rechecked every thing, and rechecked the sheet metal nut, Same story after that. Ran good for about a half an hour, then check engine light back on with the IPR code.
What am i missing?
Old May 20, 2010 | 10:45 PM
Talyn's Avatar
Talyn
are you loosing oil?
Old May 20, 2010 | 11:49 PM
AXE168's Avatar
AXE168
I lost some while changing the IPR but not more than a quart. At 322k it has a few drips here and there but I wouldnt think i would be loosing enought to effect the way it runs
Old May 21, 2010 | 06:22 AM
Talyn's Avatar
Talyn
Are you sure its not your IPR acting up?
Pull the connector and check for oil in the sensor.
Old May 21, 2010 | 07:52 AM
Action4478's Avatar
Action4478
What am i missing?
I didn't know there was an IPR code. What number was it?..
Old May 21, 2010 | 07:53 AM
Talyn's Avatar
Talyn
Yea. I didn't think so either Rick. Thats why I think he's getting ICP code.
Old May 21, 2010 | 08:20 AM
DRRXR's Avatar
DRRXR
He probably is getting a P1283 Code on that 95
Old May 21, 2010 | 02:26 PM
AXE168's Avatar
AXE168
It's showing P1211
Old May 21, 2010 | 03:44 PM
Talyn's Avatar
Talyn
DTC P1211 indicates that injection control pressure was above or below commanded desired pressure during self test mode.
Possible causes:
incorrect oil or viscosity
poor oil quality
gel fuel/no fuel
low fuel pressure
damaged IPR valve
high-pressure oil system leak
damaged high-pressure oil pump
damaged PCM
Verify correct oil quality/viscosity and correct fuel grade are being used for the temperature conditions.
Wouldn't the ICP figure this code for high or low on the pressure?
Old May 21, 2010 | 03:51 PM
DRRXR's Avatar
DRRXR
It's showing P1211
About 3/4 the way down in this document you will find your code.
X7 KOER ON-DEMAND DIAGNOSTIC TROUBLE CODE (DTC) 1211
Old May 21, 2010 | 03:54 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Possible causes:
poor oil quality
gel fuel/no fuel
low fuel pressure
damaged IPR valve
damaged PCM
Serious question, tell me how the fuel pressure is going to have any effect on the ICP..... i have never heard of a P1211 code from having low fuel pressure or gelled fuel/no fuel.. i would unplug the ICP and see how it runs...
Old May 21, 2010 | 04:02 PM
DRRXR's Avatar
DRRXR
2 X on that
If he added something to clean his oil up the trash can hang up the ipr, been there.
Old May 21, 2010 | 04:04 PM
Talyn's Avatar
Talyn
I found it from somebody else's post travis, I have no idea myself.
Old May 21, 2010 | 04:08 PM
DRRXR's Avatar
DRRXR
Now thats tellin on your self right there. Thats some funny Sheet.
Old May 21, 2010 | 04:10 PM
strokin'_tatsch
linky no worky for me...
What he said!!!^^^^ LoL
