Modular V10 (6.8l)
Whats normal compression?
Old May 20, 2010 | 09:54 PM
bill11012's Avatar
bill11012
Modular motor junkie
I tested my compression well doing a plug change and it was only 115-120 PSI.
What should it be on a normal, healty engine?
It seems to run great and I though it would be higher than that...
Old May 21, 2010 | 06:24 AM
bakon's Avatar
bakon
That is a low number but I dont know what the v-10 should be. It is listed as 9:1 in my 2003 owners manual. On Harley compression checks that would be anywhere from 170-180. The key is to disconnect the injector, ground the plug and open the throttle body plate completely. I dont know if it is the same on the trucks. Sorry to be of little help.
Did they all measure the same? That is the important part.
Old May 21, 2010 | 06:59 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Bill, do you open the throttle plate while doing it, AND did you have all the other plugs out of the engine at the time?
Cam timing/duration has a lot to do with "static" compression, but you're right, I would have thought it would be higher than what you found.
Old May 21, 2010 | 11:33 AM
bill11012's Avatar
bill11012
No, throttle was closed and most of the other plugs were in.
They did all come out the same.
Old May 22, 2010 | 10:55 AM
krewat's Avatar
krewat
Then it makes perfect sense. The throttle should be open during a compression check, just so you can compare with other compression tests or the "book".
But with it closed, as long as they all came out the same (or within 10% I think), that's PERFECT.
Sounds like you have a great long-life motor in there
Old May 22, 2010 | 11:10 AM
bill11012's Avatar
bill11012
Originally Posted by Krewat
that's PERFECT.
Awsome!
chamblizi
Jul 26, 2012 06:02 PM
IsoGrifo
Oct 16, 2009 06:37 PM
riverbottom
1997 - 2003 F150
Oct 15, 2009 01:55 PM
CAMOBRUTE750i
Modular V8 (4.6L, 5.4L)
Apr 28, 2009 05:34 PM
MontanaFord
13
Jun 27, 2004 01:18 PM
