starter bolts?
Old May 20, 2010 | 08:58 PM
Vinford's Avatar
Vinford
starter bolts?
Needing some info please.
Im kinda stuck in a bad spot and trying to take my starter off.
Anyone know how many bolts and what size they are?
From feeling around it seems like theres 2 and they are diffrent sizes?
Thanks ahead of time.
Old May 20, 2010 | 09:36 PM
WilsonTaylor's Avatar
WilsonTaylor
Actually there are 3 bolts in a PSD starter, but mine only has 2 in it (the bottom 2). They are the same size. The top one was apparently left out by the PO at some point in time (it is a PITA to remove and replace), but it has not affected the performance of the starters that I have had. I cannot remember what size socket the bolts need.
Old May 20, 2010 | 10:16 PM
Ponyboychris's Avatar
Ponyboychris
My 02 truck had only two bolts on the ears of the starter but three on the bellhousing. At some point, they changed the design.
Old May 21, 2010 | 12:44 AM
brian42's Avatar
brian42
Veteran: Navy
Same on my '03. IIRC they are either 17mm or 19mm. It is a good idea to periodically check them as they are known to back themselves out over time.
70-360fe
Nov 11, 2013 10:00 PM
shore
Modular V10 (6.8l)
Sep 27, 2013 08:03 PM
Yougotthehit
Jan 18, 2012 11:07 PM
ETHEL
Apr 25, 2007 11:43 AM
