96 turn signal problem
Old May 20, 2010 | 01:11 AM
38-72's Avatar
38-72
My 96 f250 has a turn signal problem. With the tilt wheel all the way down, the left turn signal will not flash the dash or outside lights. I can hear the flasher working, but no bulbs will light up (dash and outside). If I move the steering wheel up one click, the left turn lights work (dash and outside). The right turn signal works just fine. Any guess as to what might be wrong?
Old May 20, 2010 | 08:49 AM
acom01's Avatar
acom01
Check all the wires that goes to the steering column. I think one of them may be loose in the lower position and when you move it up it makes contact again. Take off the steering colum plastic covers with the wheel down, and with the turn signal on, move the wires to look if you find wich is.
Chisum5013
Mar 10, 2016 08:17 PM
Bradley Ripley
Feb 22, 2016 10:51 PM
BillJones
Aug 25, 2014 02:53 PM
stownsen914
Apr 23, 2014 08:44 AM
jbsmith_84
Feb 29, 2012 07:01 PM
