blue smoke
Old Feb 2, 2003 | 06:53 PM
expedition99's Avatar
expedition99
blue smoke
i start up my expy today and blue smoke came out of the exhust but it stop. what could it be. its a99 with 4.6 with 59k.
Old Feb 2, 2003 | 07:33 PM
1999XLT's Avatar
1999XLT
blue smoke
Blue smoke USUALLY means oil entering into the combustion mix somewhere. If you have a code reader check the codes. If not and you have an Autozone near you they usually hook you up and read the codes at no charge. Not much but its a start I guess.
Old Feb 3, 2003 | 11:40 AM
michaelskerrett's Avatar
michaelskerrett
blue smoke
While it is a good idea to see if there are any diagnostic codes in the PCM, oil in the combustion chamber usually will not cause a fault by itself. Things that can cause this are a fouled PCV valve causing oil vapor to enter through the intake, worn valve seats causing oil to enter from the top or worn piston rings causing oil to work past the piston from the crankcase. Since you say it occurs at startup and then stops after a short while the top end worn valve seat scenario is quite likely. You may want to ensure the PCV is working and that the vacuum line to it is tight and not leaking. How much oil do you add between changes? If it is more than about 1/2 quart low after 3000 miles check the compression of each cylinder to see if the rings and valve seats are worn.
Shawn99tj
Feb 12, 2013 07:13 PM
Joe Finn
1997 - 2003 F150
Apr 21, 2008 11:23 AM
adambomb
Feb 25, 2007 12:05 AM
bronco cam
1978 - 1996 Big Bronco
Jan 13, 2003 01:52 PM
jbulson
Jun 25, 2002 07:07 AM
