6.0 diesel noise suppression -- XLT vs. XL
#46
#47
#49
Be sure you don't snuff out something that needs ventilation, and also trip up in other ways.
#50
Assuming you don't have a moisture problem, fiberglass mat there works real good --- though a layer of lead foil to absorb the sound and deaden it would be great there -- a high noise environment.
#51
Trying to kludge together fiberglass would be a waste of time.
#53
I know I'm resurrecting this thread, but I just got a hood liner today from a salvage, with the clips, for $20. It's not new, but neither is my truck. It was in great shape really. I thought it was a good price.
#54
man no offense but just suck it up and deal with the noise. It could be worse, you could have one of the new 6.7s which you cant even hear if the damn thing is running. Diesels arent what they used to be. I think the 6.0 is the perfect volume. Loud enough to hear it and sound good, but not loud enough to be annoying. To each his own i guess...
#55
hood insulators
Early years did, but after about '05 they eliminated it. Most think it was a cost cutting effort, not for any technical reason, because at the same time they took away rear wheel well liners, puddle lamps in the doors, etc. I think the King Ranch might have retained the hood liner for the longest. Pretty hard to believe it is NLA. I would find a VIN for any King Ranch, easily found on truck sales sites, and give that to FTEpartsguy so he can look up a part number for you.
#56
Just take it off. Won't hurt anything to not use it. If you notice a difference in noise, and I don't think it will be enough to bother, then look for a replacement. I can't help with cleaning it.
#57
Like what I think about ARP studs, and tunes, Magnaflow Turbo Back,Edge Insight, RhinoLiner,Retrax Cover, Cab Lights Retro-fit, Overhead Console Retro-fit, Bilsteins, Harpooned, C-Betrs,Fumoto, '08 Diff Cover, Upfitters Retro-fit, Fleetwood Pioneer,23'x5,200#so on.
"waste of effort" so to speak...
The difference with an audio application is whether climate control is an issue, and also what leeway there is to work with in terms of space, cost, etc.
Hand Clutch
02-11-2011 08:31 AM
