1978 - 1996 Big Bronco
power chips, module's, etc.....???
Old May 19, 2010 | 08:51 PM
thsixscrews's Avatar
thsixscrews
Ok, this might be an absolutely stupid question....but I am goinna ask it anyway. What would be the best power chip, module, etc.... to get for better mpg's, power, etc... I haven't bought anything like that for along time, and never anything for a ford. It would be for a 96 xl with a 5.0, auto. The only performance mods to date is a K&N filter (replacement filter) and the exhaust cut from behind the cat, 3" into a generic flowmaster and dumped at the rearend. Sounds great, would love a lil more git up n go, and everyone could use some more mpg's.... Thanx a bunch guy's..and girl's...
Kent
Old May 19, 2010 | 10:30 PM
Conanski's Avatar
Conanski
Don't wast your money, chips are no good unless the motor has forced induction. If you don't have strict smog rules to conform to I suggest you ditch the rest of the exhaust and install shorties and an aftermarket Y.. the stock cats are a cork. Then get a timing light and add some more timing, base setting is 10deg from the factory but these motors will often take 2-4deg more before detonation becomes audible. The other best thing you can do for the 5.0 is put more gearing in the axles, all these 5.0 trucks should have got 3.73 minimum and if you have larger than stock tires don't be afraid of going to 4.10's.
Old May 20, 2010 | 03:26 AM
thsixscrews
Thanx Paul, get some coin set back and give that a shot. Guess I could go ahead and do the timing anyway tho right?
Old May 20, 2010 | 09:29 AM
Conanski's Avatar
Conanski
Yes the timing is free as long as you have a light.. and that alone will pretty much match what a chip would have done for you.
Old May 20, 2010 | 10:04 AM
Kemicalburns's Avatar
Kemicalburns
your running OBD-II so the rules are a bit different. the exhaust upgrade will be helpful. what fits a 95 bronco will fit your 96.
setting the timing if i recall is a bit different then other models due to obd-II.
Old May 21, 2010 | 10:32 PM
PIKE's Avatar
PIKE
How many miles have you got on that bad boy?A new timing chain can work wonders.
Old May 22, 2010 | 11:43 AM
thsixscrews
Thanx kemicalburns..will check into it. Pike, I only have 64,xxx on her now. She runs good, just needs a lil more giddi-up-n-go...
Old May 22, 2010 | 06:12 PM
b4hntn's Avatar
b4hntn
You may want to try some new copper plugs and be sure to keep 7 and 8 wires separated as much as possible. Check the firing order to be sure these two fire right after each other. It is 6 and 5 on my 5.8.
Old May 25, 2010 | 04:45 AM
TexasGuy001's Avatar
TexasGuy001
Don't waste your $ on chips, CAI, KN, throttle body spacers etc.
Better gears would help things quite a bit.
Old May 27, 2010 | 06:12 AM
thsixscrews
Thanx B4..I will have to make sure of that.......TexasGuy, think I will save my $$, ifn it aint goinna do me any good, I dont need em......
Old May 27, 2010 | 07:35 AM
TexasGuy001
Sorry, I'm not sure what your asking?
Old May 27, 2010 | 04:49 PM
thsixscrews
Wasn't askin anything, was just sayin ifn I don't need em, I don't need to waste my money on it.......thanx
Old May 27, 2010 | 11:16 PM
Aciancio's Avatar
Aciancio
what year did the broncos go to OBDII?
Old May 27, 2010 | 11:27 PM
Encho's Avatar
Encho
The Southernmost Mod
for what i've been told, only 96 year models.
Old May 28, 2010 | 04:55 AM
TexasGuy001
Thats cool. Yeah save your cash for something else.
