Rubbing Front Driveshaft....
Old May 19, 2010 | 08:19 PM
RangerHaywood's Avatar
RangerHaywood
Well im not sure why or how but when i bought this truck i figured out that the front driveshaft is rubbing, now to figure out how to fix this. Any Ideas?
http://sphotos.ak.fbcdn.net/hphotos-..._1407217_n.jpg
and heres another angle
http://hphotos-sjc1.fbcdn.net/hs582...._2273918_n.jpg
Old May 19, 2010 | 08:35 PM
RVDan's Avatar
RVDan
first check the motor mounts to make sure they haven't collapsed or broken causing the drivetrain shift thats making the header contact the driveshaft.
if they are good theres not much you can do except modify the header or replace it with a different style header for clearance.
Old May 19, 2010 | 08:38 PM
RangerHaywood
Oh ok that makes really good sense but if my motor mounts are crap do you think i could use a tie down to pull the header collector towards the frame or do you think that would strip out my header bolts?
Old May 25, 2010 | 09:26 PM
RangerHaywood
any ideas?
Old May 26, 2010 | 01:36 AM
RVDan's Avatar
RVDan
if your motor mounts are crap pulling on the header will likely just move the motor
its dangerous to drive on crap motor mounts too
you could go to an exhaust shop and have them heat the header until its red and then bend it
Old May 26, 2010 | 06:14 AM
RangerHaywood
yeah theres also that problem, it doesnt drive and isnt gonna drive for a few more months to come.....but i will have that done when it does! and no the motor mounts are good on it. Thanks Dentleman!
SteveBricks
S. California Chapter
653
Jul 13, 2021 11:13 PM
deadlust
65
Jul 27, 2013 04:41 PM
FuelishPleasure
Nov 9, 2010 10:48 AM
f-150 on 22's
2004 - 2008 F150
13
Oct 30, 2009 05:06 PM
HogTied
2004 - 2008 F150
22
Oct 18, 2009 10:05 AM
