Front Diff Tune-up
Old May 19, 2010 | 08:06 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke
Front Diff Tune-up
Finally got around to changing the fluid in my Front Differential @ 93K..the old fluid was pretty nasty...it was time.
Ford Truck Enthusiasts Forums - MoyockPowerstroke's Album: Front Dana Differential tune-up
Old May 19, 2010 | 08:10 PM
juneau76's Avatar
juneau76
Nice job. How'd you clean up the cover and what did you use for paint? That cover looks good.
Old May 19, 2010 | 08:38 PM
MoyockPowerstroke
I wish I had a blaster...but just a simple wire wheel and a little elbow grease...then added some Oklahoma Chrome (Silver spray paint)...and that was it.
Old May 19, 2010 | 10:28 PM
builttoughf350's Avatar
builttoughf350
how many quarts of lube did it take to do the front ? and is the rear the same amount ??
what did you use for a gasket / sealant ? good old fashioned liquid gasket ?
did you NEED the transfer pump, or did you use it for convenience ?
thanks !!
Old May 19, 2010 | 10:34 PM
MoyockPowerstroke
thanks !!
The front used nearly 3 qts 75w-90 LS and the rear used a little more than 3qts 75w-140 LS...the pump was great because both fill plugs are not too easy to use with the shape of most lube bottles... So, not necessary, but worth the few bucks for the tool. I used it for my Transfer case as well. As for sealant Permatex Ultra Black Gasket maker...worked great for the rear and front.
Old May 21, 2010 | 10:05 AM
smokersteve's Avatar
smokersteve
Do you know of a mag bolt that can replace the stock one?
