Timken wheel hubs
Old Apr 23, 2010 | 11:58 AM
beemr's Avatar
beemr
Timken wheel hubs
It seems everyone is out of the Timken hubs, but I just located some from:
carpartswholesale.com
1-800-387-8108
If you call them direct, they will discount the price from the website to $238.42 per hub delivered....for the Timken fine thread, 4wd,ABS.
They do not come with the 4 bolts to attach it to the knuckle, which are another $56 from the dealer for 8 nuts/bolts.
This is the cheapest I have been able to find them.
Good luck.
Old Apr 23, 2010 | 03:01 PM
BobbyB's Avatar
BobbyB
I replaced both of mine with National wheel hubs. They came with the four studs, needle bearing and the yellow hub seal. They were $325 each if I remember right from Advance AP.
Old Apr 23, 2010 | 06:38 PM
steelhead2's Avatar
steelhead2
holy smokes, 58 bucks for 8 studs..............i'd think the local h-ware store would have them in gr 8 alot cheaper than the dealer is getting for them.
Old Apr 23, 2010 | 09:03 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke
tascaparts.com has them for $225 each fine thread 4x4, 4w abs (with promo discount, I used their F150online discount)...the part comes with wheel bearing unit, (four knuckle mounting studs PN F81Z-1107-AA) , yellow o-ring PN F81Z-4A322-AA, and one (external opening) snap ring for hub shaft spline. You can purchase the studs separately if you need more...they are $1.87 each. Also, you can purchase the yellow oring separate at $3.62 each
Old Apr 24, 2010 | 09:37 AM
beemr's Avatar
beemr
Yes...$58 bucks.
The nuts are about $3.95 each at the dealer.
I couldn't find the Timken bearings on the tascaparts site.
Old Apr 24, 2010 | 05:19 PM
swinkw's Avatar
swinkw
Hey Guys, I work for Timken @ the plant where the Cone Assem. are made, these are mated to the hub @ Altivista Va. The Unfortunate thing is we are no longer going to manufacture these; or so I am told. But we might it is hard to say for sure. It all comes down to profitability. Hard to compete with China @ .50/hr. These assemblies may look simple, but they are difficult to produce.
Old May 21, 2010 | 11:28 AM
adisont's Avatar
adisont
anyone have the correct part number for the front hubs on a 2005 4wd 4wabs. i looked on the tascaparts website and i can locate them. also were the 04 and 05's the same a found a place with them listed for 04 and 05. rear abs only. can the abs sensor be transfered to the new hubs?
Old May 21, 2010 | 11:38 AM
gearloose1's Avatar
gearloose1
You hit it right on.
They are actually very hard to manufacture - lots of black magic, trade secrets in it.
China is not all that competitive once you get to the higher quality stuff.
For things like bearings, I always insist on name brands that have something to lose --- and even then, got to be real careful that it is not a fake or counterfeit ---- because it is so hard to tell.
Needless to say, I don't buy parts like that off e bay.
Old May 21, 2010 | 11:48 AM
CampSpringsJohn's Avatar
CampSpringsJohn
Avoid the china bearings if you can. They are junk when compared to timken.
Swinkw, I would like to talk to you about timken. Tried to PM you, but can't.
PatrickinWI
Feb 26, 2015 05:10 AM
dpilot83
Sep 21, 2014 10:03 PM
chefcollins1
Jul 14, 2014 05:05 AM
Macmathews
26
Mar 25, 2014 02:27 AM
expydaddy
Oct 5, 2013 11:11 PM
