Ive got a 60 F100 with a 292 in it and was wondering what you guys recommend for oil and how many quarts does it take thanks guys
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Assuming that it's in good mechanical condition and isn't burning any oil, any good quality 10W-30 oil would be fine, although it wouldn't hurt to look into a ZDDP additive. ZDDP is necessary to properly lube the cam lobes/lifters for the sliding friction that is present. Most of the ZDDP has been stripped out of modern oils due to government regulations. It should take 5 quarts with a filter change.
thanks for the link just went on there and bought one
i'm using valvoline vr-1 it has full zinc and right now autozone is having a 1/2 off sale (til the end of the month i think)......i've depleted 4 stores so far .
^^Is that nation wide? I think I may go get some if so.
as far as i know it is.......also it says limit 12 but you can just pay for 12, then buy more after. the register will only discount 12 at a time per ticket. funny thing is the valvoline website has a deal also, buy 2 cases and the second case is free.
