Z bar pivot bracket
Old Feb 2, 2003 | 05:20 PM
Crowbar65's Avatar
Crowbar65
Exclamation Z bar pivot bracket
Hello all!
Another question on the '74 360 into '78 F350 swap I am doing.
I got down to getting the engine ready to pull and found another "little" problem to deal with.
Seems the the Z bar pivot ball is mounted on a 351m/400 specific bracket that bolts to the aft face of the bellhousing, using the engine/bellhousing bolts.
I guess I need an FE specific bracket to go on the 360 bellhousing to make this work.
Are those as hard to find as the rest of the stuff I finally laid hands on?
Would anyone have a fab drawing from which to build one?
Thanks,
Mike
Old Feb 2, 2003 | 06:38 PM
Chas1234's Avatar
Chas1234
Z bar pivot bracket
I ran into this same problem when I put a 302 into a 78 F100 that had 300 6cly . You are going to have to find a truck that has a FE engine in it . It could be a 4X4 truck or a two wheel drive 3352 or 390 the braket is the same . hope this helps
Jon
Old Feb 2, 2003 | 08:31 PM
Ratsmoker's Avatar
Ratsmoker
Z bar pivot bracket
I moved this to the 73 - 79 forum becasue these guys should be able to help you much better.
Old Feb 2, 2003 | 09:05 PM
Crowbar65's Avatar
Crowbar65
Z bar pivot bracket
ratsmoker...
Thanks for the move.
I didn't think to put it in the '73-'79 section.
Duh...
four-sixty-power
Mar 19, 2017 01:44 AM
Bearhead
Jul 1, 2015 09:37 AM
82bull
Jun 30, 2015 09:37 AM
68cabby
Mar 27, 2012 10:21 PM
Greywolf
Dec 18, 2003 07:46 PM
