Front Leaf Spring Swap.
Old May 19, 2010 | 02:03 PM
Blade79's Avatar
Blade79
I have come across a nice pair of leaf springs on a 97 f-350. I was wondering if anyone knows if these will fit on my 89 F-250? I need some new one and I can get these for free. Is this swap possible? Thanks.
Old May 19, 2010 | 02:09 PM
79Ford4x4's Avatar
79Ford4x4
It's a direct bolt in and should net a small lift. The deisel springs have a stiffer rate than the gasser 350's if memory serves me right
Old May 19, 2010 | 02:30 PM
Blade79's Avatar
Blade79
Awsome! Thanks 79!
Old May 19, 2010 | 05:13 PM
BucksTrucks's Avatar
BucksTrucks
I am pretty sure you will run in to camber issues, you made to get TTB drop brackets. The #50 springs are positive arch and most F250 springs I have seen are negative. So Im thinking it will lift it way to much to be able to adjust at the ball joint to get it right.
bigboisteiny
Jul 30, 2014 04:41 PM
BigD7575
Feb 22, 2013 03:35 AM
chris'n'md
Feb 5, 2010 12:22 PM
86fu50
May 15, 2007 09:51 PM
Windsor84
May 13, 2005 07:00 PM
