white smoke
Old May 19, 2010 | 11:57 AM
njstevens's Avatar
njstevens
white smoke
At my start up I am blowing white smoke at first which does disapates. Does this mean I am burning oil in the engine? It seems to been going on since my batteries died and i was trying to get it started after multiple times with no luck after cranking. Maybe some oil sitting in exhaust ssytem burning off or is it something i should be concerned with. I checked oil level and still the same as when i changed it over 2 months ago. Any help?
Old May 19, 2010 | 06:56 PM
mwood1973's Avatar
mwood1973
White smoke usually means water in the system. Oil smoke is usually blue.
Old May 19, 2010 | 07:13 PM
Dakrri's Avatar
Dakrri
I had that issue with my 2004 6.0 after a below zero winter night and I left her outside and did not plug it in. The next day it took 5-6 times to get her to go and then she smoke (white) like a smoke-bomb on the 4th of July.
I would have put her in the garage that night and plug it in, but I had too many beers and had my own issue getting in the house that night!
Its all good, I wouldn't worry too much about it.
dakrri
Old May 20, 2010 | 05:32 AM
katiesdad7's Avatar
katiesdad7
Your truck is ONLY 10 and its smoking? I thought you had to be 18 to smoke? :-)
Old May 20, 2010 | 09:53 AM
MagKarl's Avatar
MagKarl
Go do some reading in the 7.3L section, it's likely that your glow plug system may need some checking. Does it smell like fuel?
Realslowww
Feb 27, 2017 10:16 PM
bchitwood73
Aug 23, 2016 06:05 PM
DrewRowe
Jul 13, 2016 11:30 PM
TwoToneBullnose
Apr 10, 2015 11:30 AM
countryboy6074
May 7, 2008 05:06 PM
