1949 F1
Old May 18, 2010 | 10:55 PM
Beebol's Avatar
Beebol
1949 F1
I am trying to figure out the original color of my 1949 F1. Did the pickups of that era have paint codes located somewhere?
Thanks
Old May 18, 2010 | 11:01 PM
Lakotas53's Avatar
Lakotas53
Welcome to FTE. It should be listed on your vin# data plate. I'm not sure about the 49 model but on my 53 it was on the glove box door.
EDIT: as Havi said look on the firewall for some stamped letters and numbers. If you find them there then go up to the top of this forum and read some of the sticky 49/50 vin cutoff dates. Lots of good info that will tell you which letter/number stands for what and they have the color codes listed as well.
Old May 18, 2010 | 11:02 PM
havi's Avatar
havi
I'll have the Roast Duck
Try looking on the upper area of the cowl for a bunch of numbers and letters.
Old May 18, 2010 | 11:08 PM
Julies Cool F1's Avatar
Julies Cool F1
Hi Beebol
Welcome to FTE!
Unlike the 1951s and up, there was no paint code stamped on any of the Glove Box Door Rating Plate, etc.
I would try looking up under the dash, perhaps under the windshield rubber, under the steering wheel seal plates, or places they normally wouldn't repaint in a new paint job for something original - there aren't whole lot of choices.
The 49s had 5 basic colors: Chrome Yellow; Meadow Green; Vermillion (Red); Birch Gray; and, Black.
Here is a link to Earls world here at FTE with chips of those colors - you may have to scroll down to find the right topic line:
http://www.clubfte.com/users/earl/Re...aterial_2.html
The Meadow Green on the chart looks very dark. It was about the same color as Forestry Service Vehicles
Old May 18, 2010 | 11:33 PM
mtflat's Avatar
mtflat
Thanks
As Havi said, look at your firewall, just below the cowl for a series of stamped letters/numbers that are stamped into the body itself. They can be anyplace but usually center-to-driver's side. This was the production code, but not all assembly plants stamped them and there is a lot of variation between plants.
You're looking for something like 7RHI2L6025
It tells color, plant, date and vehicle down the line. Post what you find and I'll help you interpret it.
Old May 19, 2010 | 12:17 AM
52 Merc's Avatar
52 Merc
Thanks
As noted, there weren't that many color options, so a little forensic research should give you a good clue. Look under and behind the seat, the gas tank, or the interior trim panels, kick panels or firewall insulation. You might also take off one of the access panels on the doors.
1949f1
Testing.....
Apr 16, 2016 01:53 PM
fifty-two_f1
WTB - Parts & other
Dec 27, 2015 10:23 PM
brooksdw
Dec 1, 2015 02:02 AM
rbr658
Jul 15, 2015 11:34 AM
oscardgarza
Apr 2, 2013 07:30 AM
