Has anyone EVER seen this?
Old May 18, 2010 | 05:30 PM
CharlesFrankenstein's Avatar
CharlesFrankenstein
Okay so I was flat towing my blown up truck from cincinnati ohio to Charlotte North Carolina this past weekend. Around 7am I pull into a burger king and hop out of the uHaul and of course glance over at my truck and I notice the passenger caliper dangling from the hose... I think to myself "huh..." and go in and get some breakfast chicken. Come back out and crawl under the truck with a chain to tie the caliper out of harms way when I finally start thinking (I was REALLY tired) "how did the caliper get off the rotor....?" So I look over and the rotor completely disintegrated! There was nothing at all left of it! Whatever happened twisted all 8 wheel studs a little bit clockwise, the rotor is flat out missing, but luckily the wheel is still good, and nothing hit my tire. Has anyone EVER heard of that happening?!
Old May 18, 2010 | 05:47 PM
hasteranger's Avatar
hasteranger
you didn't notice it cause you were towing it, but I'm sure the brake caliper was seized or sticking and it simply overheated. You probably would have noticed had you been driving. I've seen that happen to racecars that went through intense heat cycles.
Old May 18, 2010 | 07:29 PM
Bowtie_Schmowtie's Avatar
Bowtie_Schmowtie
That's entirely possible. At first as I was looking at the picture I thought that it had been broken for awhile, as it looked as if the broken edge was rusted. I would agree that the caliper was probably sticking/ dragging, which caused a great excess of heat, and if the heat became THAT excessive, it would have eventually locked the pads to the rotor. Then you may have hit a pothole or bump in the highway, which jarred the wheel loose (after twisting your lugs) and shattered the rotor. Whatever it was, it was significant! Hopefully you didn't have a locker in that axle...otherwise it may be damaged from one wheel being locked up, even if it was only for a short distance.
That must have been the big 24 foot U-Haul you were towing it with to not notice that much carnage taking place! If you had been driving it you might not be talking to us right now.
Something else comes to mind. Is the caliper itself gouged or scarred, or is the hose badly damaged? In thinking about the force needed to remove a caliper from its mount when it is properly installed, I had the idea that perhaps the caliper was not well secured to the spindle, came off at some point, and smashed into the rotor itself, shattering it.
Last edited by Bowtie_Schmowtie; May 18, 2010 at 07:41 PM. Reason: Had another thought.
Old May 19, 2010 | 09:13 AM
hasteranger
That is possible, too. I had a caliper bolt fall off of my nissan pathfinder, and the caliper turned out, spinning down the inside of the wheel like a lathe, before locking up my right front going down the interstate. I immediately pulled over (obviously) but it had done a decent bit of damage. Probably if it was being towed much further something similar would have happened. I'm also eyeing what looks like scratches on the inside of your wheel.
