tachometer
Old May 18, 2010 | 03:58 PM
gumper 123's Avatar
gumper 123
tachometer
ok fellows changed out tach sesor still have same problem tach comes and goes not good good on my e4od. traced wires from sensor to left hand side feneder were it plugs in to set that go across front of truck any ideas could not see any thing wrong there. where can i find a diagram for this or does some one have an idea.
Old May 18, 2010 | 08:36 PM
PLC7.3's Avatar
PLC7.3
Try doing a connector check on all the ones on the rear of the cluster...... just wiggle them to tighten them up.
Old May 19, 2010 | 11:43 AM
gumper 123's Avatar
gumper 123
checked and re check all connection stiil comes and goes is driving me crazy
Old May 19, 2010 | 02:02 PM
johnboggs21's Avatar
johnboggs21
did you get a new tach, or a jyard one? You almost have to get them new to be sure their good.
Old May 19, 2010 | 03:00 PM
gumper 123's Avatar
gumper 123
No i did not change tack it self just sensor.
Old May 19, 2010 | 06:12 PM
gumper 123's Avatar
gumper 123
ok so i found a guy on the net that says that the sensor should ohm out at 2000-3000 ohms with the sensor out of the truck can anyone back this up
Old May 19, 2010 | 08:05 PM
johnboggs21
sorry i ment to say tach sensor not tach. Their is a way to test the sensor, but Im not sure what it is. Im sure theirs a thread on here about it somewhere.
Old May 25, 2010 | 01:34 PM
iverger's Avatar
iverger
Bumping this thread. I am suffering from something very similar. Mine is dead until it warms up little and then seems to be good for the rest of the day.
A schematic would be very helpful. I've replaced the tach sensor twice, by-passed the 3-prong grey connector that sits near the alternator relay and pulled the dash cluster and cleaned the connectors. I'll try the connection at the transmission next and then I guess I'll have to try a new/used tach then a replacement cluster.
Maybe easier to do a ZF5 conversion at least then the tach will be downgraded from mandatory to just handy. Friggin electronics anyway.
kyle.good
1997 - 2003 F150
Sep 27, 2011 11:33 PM
MUDN69
23
Sep 1, 2007 08:44 AM
bterry
Jul 30, 2006 07:07 PM
leisjohn
Jul 21, 2003 03:02 PM
mustanguru
Jul 9, 2003 04:43 PM
