Removing 2nd row bench seat?
I'm considering buying an '05 Ex with the Eddie Bauer 2nd and 3rd row bench seating but first wanted to know how 'easy' it is to remove the 2nd row bench? Are we talking just a few bolts and nuts or is it a time consuming job? Thanks a lot for your help. Graham.
Are you talking about removing it completely or replacing it with captain's chairs in the 2nd row?
Heres some info I put together on the 2nd row swap: https://www.ford-trucks.com/forums/8...l-it-work.html
Removing is easy, finding matching Captains chairs is hard... hope that helps
Can I remove the 2nd row bench exclusively from inside the cab or do I also need to crawl underneath to undo the hardware? Thanks, Graham
Not 100% sure, but every late model ford I have done seat removal on is done through cab only access (nothing underneath, all the nuts are welded on the body underneath)
Big Torx head bolts holding seat and belt points, nothing else.
Taking them out should easily be done in under an hour if you have done it more than once. First time is just going to be figuring out the easiest way out (through back or 2nd row doors, I am going to guess through the back)
Good luck
Good luck
Good luck
Good luck
