Help i gotta steam!!!!
Old May 19, 2010 | 08:28 PM
Skip1970's Avatar
Skip1970
Originally Posted by Dbailey
Bump!! No one esles has a clue starmit, none of you guys
sounds like a whistle tip. but anyhow maybe when they welded the exhaust there is a piece of welding wire that went in the pipe giving it the whistle tip effect.
Old May 19, 2010 | 10:51 PM
Dbailey's Avatar
Dbailey
I am talking about the clapping noise.
Old May 20, 2010 | 01:33 AM
rupejosh's Avatar
rupejosh
lol starmilt is truckin away in AK last i knew.i havent seen him around
Old May 20, 2010 | 01:41 AM
Dbailey's Avatar
Dbailey
Do you know what the sound is rupejosh. My truck is identical to yours but, its a 86 not a 94 same color and everythang
Old May 20, 2010 | 02:35 AM
rupejosh's Avatar
rupejosh
i couldnt hear the sound but your engine does seem noisy.when was the last oil change?what oil was used?im wondering if it might be relative to the noise your hearing.
Old May 20, 2010 | 02:18 PM
Dbailey's Avatar
Dbailey
i probaly need to change it ill try that and get back with you guys
thanks for everythang
Old May 20, 2010 | 02:57 PM
BlueOvalBud's Avatar
BlueOvalBud
Is the noise ONLY from the tailpipe? Is the noise loud in the engine bay area?
It sounds a lot like my sister's Jeep with the leaking exhaust manifold...
I've seen a few guys on here post pictures and talk about cracked exhaust manifolds, psycho even posted a picture where it cracked in half!
I don't know much about valves or engine internal parts, but maybe something broke loose inside?
Old May 20, 2010 | 06:11 PM
Dbailey's Avatar
Dbailey
I can here it mostly coming from the exhuast. I dont thank i can here anythang up by the motor area. I even climp under it to see if the monifold connection was not seated right becuase i put the y pipe on it. It looks pretty good to me. Guess ill drive tell she blows got a 1985 that is pretty rusty so i can use motor out of it and scrap the other one.
Thanks for eveythang
