Anything else I should do when swapping intake/carb?
Old May 17, 2010 | 08:05 PM
xirxious's Avatar
xirxious
i finaly got my carb & intake in for my '86 F250 460. I planned on the usual gaskets, thermostat, dist. gasket, PCV valve and removing any emissions left overs. Anything else I should tackle? I'll probably do a full tune up with distributor/plugs/wires. Gas filter, air filter & housing, misc wire removal.... I'm hoping most of the vacuum lines will be sorrted proper. the P.O. removed the smog pump and put a hillbilly bracket back in. I'd like to get a 70's alternator mount to put back in. Something other than a big slab of steel.
WRONG FORUM, re-posted in correct year
