Fuel Gauge
Old May 17, 2010 | 07:59 PM
lsramek1's Avatar
lsramek1
Fuel Gauge
I have a 2005 F250. I long ago installed a RDS auxilary tank in the bed and I am now wondering if I could get a fuel sensor to put into the tank that I could wire into the factory gauge. Does any one know of one that would work and could be wired into the factory gauge? Anyone know the resistance that our gauges work on? I found one post that says something like 15 - 160 ohms.
Thanks for your help in advance.
Old May 17, 2010 | 08:22 PM
gearloose1's Avatar
gearloose1
How would you wire a factory gauge to read 2 different tanks?
Old May 17, 2010 | 08:45 PM
lsramek1's Avatar
lsramek1
I have an electric valve that controls wich tank I use via a toggle switch. The valve I believe can be wired for the fuel gauge so you can read both tanks.
Old May 17, 2010 | 09:45 PM
gearloose1's Avatar
gearloose1
I am not sure it is so simple.
Does the stock Ford sender unit just send fuel levels? Or does it do more like monitoring for a vacuum break?
Doesn't the gauge do calibration while it "wakes up"?
Can you switch it in mid stream and not have the PCM think the sky has fallen?
F350moneypit
Jan 23, 2013 12:07 PM
sportfuryjoe
Jul 2, 2012 10:10 AM
Ranger350
Mar 15, 2011 09:40 AM
gadams
Aug 26, 2002 11:22 PM
brenda
Electrical Systems/Wiring
Aug 8, 2000 11:37 PM
