6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
How Does Regen Know?
Old May 17, 2010 | 04:21 PM
RoadJunkie's Avatar
RoadJunkie
So, just how does the regen cycle know to begin it's execution just as you:
1) Are between stations, in the middle of nowhere, and sweating as to whether or not you will make it to the next one before running out of fuel.
2) Are just about to pull into the driveway (or end your trip) after you've just driven more than enough miles to complete the regen.
3) Are towing your rig and pulling up the only high-grade mountain on the trip.
4) Any other time it is most inconvenient.
How does it know?
Old May 17, 2010 | 07:02 PM
Grodyman's Avatar
Grodyman
I think when the LieOMeter reads over 12 MPG, the computer automatically puts the truck into regen, so your MPG will go back down to where it belongs.
Old May 17, 2010 | 08:27 PM
cheezit's Avatar
cheezit
do you really want the awnser as to when and why regens happen
Old May 17, 2010 | 08:37 PM
senix's Avatar
senix
It is a total crap shoot. I ask Chris Brewer about giving us an option based upon a need to regen in XX miles, followed by a PCM controlled regen should the driver not pushing the button...but you see where we are with that suggestion.
Just drive the truck.
Old May 18, 2010 | 06:33 AM
Gearitis's Avatar
Gearitis
I have wondered the same on "how does it know" to regen just as I am pulling in the drive? I have just accepted it and go on and drive the dang thing. You are not going to change it much.
Old May 18, 2010 | 12:07 PM
aquaman's Avatar
aquaman
Wouldn't it be nice if we could simply flip the DPF around 180 everytime it needs to regen and just let all the soot blow onto the ground or disposable collection bag? Nah... that's too easy
Old May 19, 2010 | 07:00 AM
waverunner800's Avatar
waverunner800
The truck's computer is constantly learning. One thing it learns, is where you live, and where you park at work. It memorizes all the little bumps in the road, and knows when you're just about to pull into the drive or park at work. If the computer is feeling vindictive, it will start a regen just to mess with you. It also talks to other Superdutys on the road. They are constantly asking each other when they've initiated a regen that most pi$$ed off their owner. They are constantly trying to out do one another. One I know of, the owner had to pee really bad. I mean REALLY bad. The computer knew this, because the seats were telling it the driver was squirming around. So, as soon as he got near the rest area, it threw the "DRIVE TO CLEAN EXHAUST" message up, just to see if he would keep going, and wet his pants. Once the seat figured this out, though, it got sort of upset (who wants to get peed on, right?), and decided to send the computer a message that put the truck in limp mode, thinking that would make the driver turn off at the rest stop. However, this backfired on the seat. Since the truck was in limp mode, it was going very sssllllooowww....so, you can guess what happened next...
Old May 19, 2010 | 07:18 AM
senix's Avatar
senix
I'm thinkin that you desire a lot reps for that one!
Old May 19, 2010 | 04:42 PM
ruschejj's Avatar
ruschejj
Also, anyone ever ride behind their truck on a motorcycle or scooter? Man they smell bad! Especially in regen. Now every time a cycle is riding my a$$ I get a little smirk on my face!
Old May 23, 2010 | 01:59 AM
Toms53Ford's Avatar
Toms53Ford
Since i'm considering an 08 F450, what does this regen do and i'm assuming it comes on whenever it pleases? Does it slow the truck into a limp mode or what? Can the system be removed from the truck without voiding the warranty?
Old May 23, 2010 | 05:27 AM
senix's Avatar
senix
Regen as we call it refers to the cleaning of the exhaust system. Every so often the pcm tell the injectors to inject fuel on the exhaust stroke down the exhaust and into the DPF (diesel particulate filter). This basically creates and fire and burns off the soot that it collected in the dpf and then that burnt soot, now ash, goes out the pipe.
A proper running system and you will see clean tailpipes or maybe just a haze.
This cleaning operation varies according to load, fuel quality, the earth rotations and maybe the change of seasons. There is no way to control it. It is done by senors.
Removal will surely void the warranty, however there are those that put it back on for warranty work.
Old May 23, 2010 | 10:05 AM
Toms53Ford's Avatar
Toms53Ford
So when it decides it's going to clean itself, does it slow the truck down, or does it continue at highway speeds? I plan on hauling cars with it.
Old May 23, 2010 | 10:09 AM
senix's Avatar
senix
I never notice a difference. Eng hp is suppose to be slightly reduced during the event because the injectors are only putting 4 pulses of fuel in the compression stroke vs the normal 5.
That 5th one is now on the exhaust stroke to burn that soot.
I pull a 14k 5th and never notice anything.
Old May 23, 2010 | 10:31 AM
Toms53Ford's Avatar
Toms53Ford
That's good to know. I plan to pull a gooseneck with 3 vehicles on it. I'm looking at the F450 for it's 24,500# capacity.
