i have a '95 f150 XLT EB-ext. cab, short box, 351w 4x4, it has the keyless module, and i have located the grey wire, but i don't know how to "Jump" them...while at work i tried using some copper wire, bcuz it was all i had with me, but it didn't do anything...any help? thanks!
Oh yeah, it was very easy. The hardest part for me was figuring out the programming sequence. Once I got that down (came with the key fob I ordered) it was a piece of cake.
sequence? i was in the understanding that once i jumped them, and entered programming mode all i had to do was hit a button on the fob and that was all...was that incorrect?
No that is correct I believe. The sequence is posted earlier in this thread. When I first started trying it, before consulting the forum, I was using the sequence for a newer F-series truck.
when i tried it this morning i had the key in the Run position, but i guess the little wires weren't enough to jump the two. when i get a chancer here in a few hours i will try a screwdriver or paperclip or something
ok, so i tried it again, this time i heard the "clicking" that should be the doors locking/unlocking when i jumped the two...but they did not lock/unlock...and when i pushed a button it didn't do anything. not sure if it matters, but i noticed that on the bottom of the module (in your pic) i am missing the light grey connector, it's the one on the right...
Is there any way that you can take a picture and post it on here for some clarity? Is there something in the picture that I posted that matches what you have?
