Temp. question
Old May 18, 2010 | 09:06 PM
Blue50F-1's Avatar
Blue50F-1
I'm not a flatty expert, but I'd advise the thermostat should fit your area. If you live in the South/Southwest, 160's are probably better. If you live up North/North East, 180's are probably the best choice. This is general rule of thumb though. Definitely keep the thermostat in, and consider using a mechanical backup temp guage (under dash type) that will tell you actual degrees instead of just Hot or Cold. (Got burned by a falty temp guage a couple years ago...now I'll always run a back up/modern guage).
-James
TractorM3
Apr 13, 2009 12:26 PM
priv8pilot
Jul 20, 2006 10:36 AM
RepoMan801
Aug 23, 2004 06:07 AM
Josh79
Electrical Systems/Wiring
Jun 15, 2004 11:18 AM
Chuck 6083
Apr 4, 2003 01:03 PM
