She just quit
Old May 17, 2010 | 08:42 AM
orcatruck's Avatar
orcatruck
Question She just quit
Hi Guys, My 94 7.3L POWERSTROKE runs well, but it will die on its own. It starts fine and runs great until it just dies. It will also sometime stop and then strart before it totaly stops. What is going on, ideas?
Old May 17, 2010 | 09:06 AM
Hussler's Avatar
Hussler
One possibility is the CPS (cam position sensor).
Sounds like it.
Old May 17, 2010 | 09:25 AM
DRRXR's Avatar
DRRXR
Jims right. Check the wires at the cps and the connection. If there is no issues change the cps and see if that addresses the issue. If not save the old cps for later. The cps is located on the front of the engine near the crank shaft at 10 o-clock. Does the truck sputter and die or just dies? Oh and Welcome to FTE
Old May 17, 2010 | 10:31 AM
orcatruck's Avatar
orcatruck
Thanks a bunch!
I'll give that a try, thanks Jim for the great info!
