which year for a good Ranchero
I've been considering an early 60's Ranchero as a second car/truck and was wondering what problems they might have other than the obvious rust problem. I wanted one with a 6cyl. I don't want to make a hot rod out of it, just a stock one that is reliable for everyday transportaion.
Yea, falcons and rancheros are probably the same handling. Theres most likely an easy way to fix it, maybe putting in some polyurethane joints. Theres kits out there for them. Thats the problem my brother had, and he replaced all the joints and it seems to handle just fine. I haven't really heard of rancheros having alignment problems, but some probably do.
You might find what you need here. http://www.nwfalcon.com/pages/brtiwhsust.html Also, just to let you know,a stock 62 ranchero is pretty slow. 0-60 is 20 seconds. I'd say find a stock one and put a 289 or 302 in it. That will be enough power for a daily driver, and it will be reliable too.
I went with a '71 Ranchero as a daily driver truck. The newer Ranchero has a larger bed for me to haul stuff, and they seem to ride a lot better (a little more comfortable for me because of the size). I can easily put two of my kids in the seat with me. There are still a lot of Torinos around to interchange parts with.
I like the 67, it is the only year that it is a Fairlane. If you like 385 series(429-460) then you must go with the torino body. I like the FE motor. My Ranchero is a XL model wich means it has bucket seats, probably the only two seater that ford (or even anyone made except the corvette) made in 67.
If you're set on a early model, go for a '63. It has the best styling before they screwed them up royal in '64 IMO. Biggest six was the 170 back them, only auto was a 2-speed. A stock 260 model will run the quarter in 17 sec.
My '63 Falcon has no problem keeping alignments, A-arm bushings needed replacement though, squeaked too much.
Barry
Barry
