Mystery Part
Old May 15, 2010 | 09:03 PM
cueball86's Avatar
cueball86
Mystery Part
My son was driving his 73 F100 and when he returned home he could not shift out of "D" and the gearshift moved freely. I checked the linkage and everything looked fine. Read a repair manual and thought the problem might be with the shift tube. The mystery part (see picture) fell out as I was removing the column flange. This is a project truck for my son and I and we do not know enough about it yet to identify this part. Any help with its ID or how and where to put it back would be appreciated. Thanks.
Old May 15, 2010 | 09:29 PM
CalebJns's Avatar
CalebJns
First off welcome to FTE! Not sure what the part may be, it does appear to be broken at the top left of your picture. Some more information would be helpful as well. Engine? Transmission? 2wd/4wd? Things of that nature....the more info the better,
Old May 15, 2010 | 09:36 PM
cueball86's Avatar
cueball86
1973 F100 Custom, 2WD, 360, C6 Transmission. The part is actually a little larger than my thumbnail. I am not sure if it is associated with the column flange, the shift collar or neither.
cueball86's Avatar
cueball86
Old May 15, 2010 | 09:41 PM
CalebJns's Avatar
CalebJns
Is it just the pic, or is it broken at the top left?
Old May 15, 2010 | 10:00 PM
cueball86's Avatar
cueball86
It does seem to be broken at the top left and also at the bottom left.
Old May 15, 2010 | 10:27 PM
CalebJns's Avatar
CalebJns
Just looking around online, I found this website...http://www.fordification.com/tech/im...ing-column.jpg
However, there is a member here names NumberDummy...look him up, and he can more than likely tell you SUPER FAST...
Ford Truck Enthusiasts Forums - View Profile: NumberDummy
Hope this helps
Old May 15, 2010 | 10:45 PM
spudgunman's Avatar
spudgunman
I wanna say 7A216 in the diagram
Old May 15, 2010 | 10:49 PM
CalebJns's Avatar
CalebJns
That was my thoughts as well, not 100% sure though, if the other 1/2 or part was able to be found, it would be helpful...but if I had to guess, I would go with that as well...
Old May 15, 2010 | 11:00 PM
cueball86's Avatar
cueball86
7A216 looks right. The back of the flange is also broken where that piece would probably fit. Thanks for the help! I know where to get a new flange but how to I find the mystery part?
Old May 15, 2010 | 11:24 PM
CalebJns's Avatar
CalebJns
What you are looking for is an Automatic Transmission Detent Plate here is a website (found through Google Search, so can not verify any info, just sharing what I found)
Squarebirds- 1966-1977 Ford Bronco Detent Plate
