random annoying whistle
Old May 15, 2010 | 02:10 PM
sjwelds's Avatar
sjwelds
Hello everyone, My truck started making this whistling sound a few thousand miles ago. Its a high pitched squeal coming from somewhere under the hood. there doesnt seem to be any pattern or certain time when it does it. Ive read on here about an alternator problem on these trucks. Or could it be my S&B intake? any help is appreciated. thanks
Old May 15, 2010 | 09:42 PM
jdrahush's Avatar
jdrahush
I had a random annoying whistle coming from the front of my truck and after a long time of searching I found it was because of a VERY slight gap between the hood and the grill. I used a bit of silicone to seal it up and the whistle went away; others have used foam tape. I'm not saying that this is definitely your problem, but it's an extremely cheap fix and worth a shot.
Old May 16, 2010 | 08:23 AM
1bad67sbf's Avatar
1bad67sbf
your intake will whistle but only under very little throttle and can only be heard at low speeds
Old May 16, 2010 | 08:26 AM
1bad67sbf's Avatar
1bad67sbf
i see you used champion plugs. are they better at not breaking or just cheaper and did you see anything change, i was told by everyone i asked to put stock back in
Old May 16, 2010 | 02:52 PM
sjwelds's Avatar
sjwelds
well they are a one piece plug rather than the two piece OEM design. I read about plug breakage problems on this forum and decided to change mine out. I broke four of them and had to buy the lisle tool to remove them. just looking at the plug you can see the obvious design flaw. the champion plugs are one piece and should never break. they are also a hundred thousand mile plug so I should be good for awhile.
Old May 16, 2010 | 03:17 PM
1bad67sbf's Avatar
1bad67sbf
i had mine done and 4 broke also, both front and both rears and that was at 70k so around 110k or 120k i will change them again. how much did they cost?
Old May 18, 2010 | 06:17 PM
sjwelds's Avatar
sjwelds
I think something like twelve dollars apiece on rockauto.com... worth it to me cause i dont have to worry about them breaking again.
Old May 18, 2010 | 10:49 PM
williamsfw2427's Avatar
williamsfw2427
I just picked up a 2006 a few weeks ago and last week as I was coming to a stop and I heard a weird whistle... I called the guys at the Ford dealer where the company gets all the trucks serviced at and they told me they had never heard of that problem.... All they could think it might be was because we've been having a lot of rain and it might be something to do with the belt.. It sounds like some type of kids toy when I hear the sound and I only hear it when I'm coming to a stop...
Old May 19, 2010 | 12:28 PM
sjwelds's Avatar
sjwelds
I am starting to think that its my alternator. I have electric fans on my truck and one is wired to come on whenever the a/c compressor kicks in. it seems like whenever the a/c is on that the noise is louder, which would make sense because of the higher load on the alternator. what do you all think?
Old May 13, 2017 | 10:42 PM
KELA83's Avatar
KELA83
Do you remember what the issue was and how you fixed it?
HI! I'm having the exact same issue pretty much with my ford truck. Some days I don't hear it, others at different points in time during my drive. Sometimes the whistle is soft and others super loud where I hear it over the music I play. I had taken it to a mechanic who checked everything he could and couldn't figure it out. I'm hoping maybe you could she'd some light. Anything would be appreciated. 😊
Old May 25, 2017 | 11:20 AM
Kijutsu's Avatar
Kijutsu
Its the alternator bearings -- happens to mine a lot when the temperature drops or it gets humid. Been running on that same alternator for probably 7 years now, haven't had a problem with it.
Old Jun 17, 2017 | 08:47 PM
stresssolutions's Avatar
stresssolutions
Curious how you go about finding the whistle? Other than looking for weird/odd gaps and filling them? My bus, F550 with Glaval body has a loud whistle above 45. When the bus is wet, it doesn't whistle.
Thanks
Old Jun 19, 2017 | 11:21 AM
redfishtd's Avatar
redfishtd
This can be funny
As I have run whistles for deer in my grills for years to keep from hitting them.
My company cars ,wife's car greatly reduced close calls . Central northern fl ,deer are everywhere at dark . But I realize you are worried about something going bad .
Old Jun 25, 2017 | 10:50 PM
Black Helmet's Avatar
Black Helmet
I've had the alternator whistle with extreme cold temps, pitch almost seems to follow engine RPM. Also, check your cowl and make sure it is tight to the windshield.
Nick9219
17
Sep 12, 2021 11:40 PM
olfordsnstone
Aug 25, 2017 12:05 PM
94bonestocker
Sep 16, 2016 05:18 AM
tfunk88
Sep 12, 2016 10:34 AM
jofes
Jul 13, 2016 09:04 PM
