Zip tied fan shroud because clips wouldn't work on new radiator, had to use generic upper hose because the stores didn't have a line on the correct hose (the one I did get was 7 inches off of where it was supposed to go).
the down pipe I managed to find without a cat:
my rebuilt carb, with a dashpot that disintegrated shortly after the engine came back to life.
t-18 hiding in the dark:
bushing mount from the 302 because I neglected to obtain one ant the junk yard
You need to get that upper radiator hose so it doesn't go up then back down leaving a high point, it could vapor lock right there and cause heating issues... technically it should slope slightly all the way up.
fh, I'm not sure how I would do that, because the water neck there exits the block vertically and the radiator inlet is roughly at the same level. Maybe a shorter hose but if I bend that one at all, it kinks...
would it vapor lock being on the positive pressure side of the pump?
Reason: ?
You need to get an original thats formed and possibly modify it a bit.
Sounds like it wouldn't reach the radiator ... Cut it in a straight location that if extended will get it to the right location and add a section ... Or use TWO and cut and splice.
I can tell from looking at the rad, you need the factory A/C upper hose. The non a/c rad was narrower (~22") than a/c (~27"). That what the other set of holes in top of the rad support are for.
Looks great! T18 is a huge upgrade over the OD, as far as towing and strength, but comes with a minor MPG hit on the hyw, unloaded.
I always amke a joke about these trucks offering 2 styles of 4 speed tran, and both had 1 gear that was only useful under certain conditions. I'd rather the seldom used gear be at the bottom, to make heavy things move easier, than at top to make a couple extra MPG unloaded.
Just curious, what rear gears are under that?
Great job getting it back together and running. It should last you many years to come, with just a little regular maintainance.
