leaf spring questions
Old May 14, 2010 | 09:55 PM
ultraking's Avatar
ultraking
if i take the rear 6" leaf spring out of my 76 f150 and put the in the rear of a 78 f250 what lift springs would i have to buy for the front?
Old May 14, 2010 | 10:51 PM
MTcountryboy's Avatar
MTcountryboy
The half ton springs aren't going to have as many leafs as the 3/4 ton but if you were to switch make sure they are the same width. For the front you will need new springs. I am not sure it SD springs fit on a 78 but they make four inch springs then just drop the shackle. Going this big is going to affect you pinion angle and steering so some modifications will be required.
Old May 15, 2010 | 10:58 AM
mark a.'s Avatar
mark a.
I would check the width of the rear springs under the f150. The f250 would have the 3" wide rear springs. Not sure about the f150 ?
Old May 15, 2010 | 11:10 AM
fatdan460's Avatar
fatdan460
i believe the f150's came with both 2.5'' and 3'' rear springs, so measure first. if they are 3'' wide, then a set of 4'' front springs would probably make it sit nice. super duty springs work, but are not a simple bolt on. if you aren't into fabricating, just buy the correct front springs for your truck
Old May 15, 2010 | 09:53 PM
ultraking's Avatar
ultraking
my 1/2 ton rear spring are 3" and have 5 leaves i'm not looking for towing capacity so if they hold up a 1/2 ton they'll hold up a 3/4 ton. as for the front springs if a man didn't want to lower the shackles and bought 6" front springs how much height difference f/r would there be? i was thinking if its higher in the front to flip the rear shackles and adding a shorter block or if it's higher in the rear either using a shorter block or removing it completely.
Old May 15, 2010 | 10:01 PM
fatdan460's Avatar
fatdan460
4'' front springs would probably match the 6'' rears in hieght perfectly.
