Sponsored by: Real Truck
turn signal problem
Old May 14, 2010 | 09:45 PM
Hawghunter001's Avatar
Hawghunter001
turn signal problem
HELP ! I am having problems with the right turn/stop light on my 1999 F250 Super Duty. I have replaced the bulb socket, however, the brake /turn light may work sometimes and not sometimes. It may work once or twice then not work for a day or two, then work again for a while. My local mechanic has run out of ideas for repair. This has been going on for about 2 months and is very frustrating. Can anyone help? Thanks!
Old May 15, 2010 | 07:07 PM
bpounds's Avatar
bpounds
The switch in the steering column???
Old May 18, 2010 | 01:05 PM
thomabb's Avatar
thomabb
When it stops working, do you still have power to the socket? It could be a loose or corroded ground wire.
