Exhaust in cab.
Old May 14, 2010 | 08:40 PM
BEAR_34's Avatar
BEAR_34
Exhaust in cab.
2005 Ford 6.0L
I am getting diesel exhaust coming thru my vents ONLY when the fan/heater/ac is turned on. The exhaust goes away when I start moving down the road again. The fan is sucking it up from somewhere. No fan = no exhaust in the cab.
If I am at a stop and pointing into the wind w/ fan on...no exhaust blown thru vents. If I am at a stop with fan on and the wind blowing up from behind, I get exhaust. Exhaust always present backing up w/ fan on.
I get fresh air coming thru the vents only when the truck is moving forward or is pointed into the wind.
The problem started after one of the blue turbo hoses blew off. Immediately the cab filled up with exhaust. I replaced the blue turbo hose but now I am left with this problem of exhaust coming thru my vents when the fan on.
I had it in to 2 different mechanics look at it. Did the smoke test and all....y-pipe, ect, ect. NO luck! An ideas????
Old May 14, 2010 | 08:45 PM
liv's Avatar
liv
I'm guessing that boot needs to be replaced.
Old May 14, 2010 | 10:34 PM
BEAR_34's Avatar
BEAR_34
Boot? I replaced all the blue turbo hoses.
Old May 14, 2010 | 11:47 PM
flamebuster's Avatar
flamebuster
Look over the entire exhaust system, should be the tale tale signs of black carbon at the source of the leak. I have a couple of small leaks at the manifolds but the air flow seems to blow them underneath the truck. Could be the flanges at the turbo from the pipe swinging up when the hose blew off. They are possible now out alignment or just need tightning... You might be able to feel the exhaust leaking but you obviously have to do it right after starting when the pipes are cold.
Old May 15, 2010 | 12:40 AM
BEAR_34's Avatar
BEAR_34
THANKS. I will feel for exhaust leaks and look for black carbon.
Any other signs that I should look for?
Old May 15, 2010 | 12:44 PM
4604x4's Avatar
4604x4
I had the up pipe to the turbo from the dr. side manifold replaced. i had fumes in the cab from a leak in it. Pipe is like $250 from Ford
Old May 15, 2010 | 01:46 PM
janton01's Avatar
janton01
Something else to look at is the rubber seal along the back of the hood. The air intake for the cab is right in front of the windshield and mine was not sealing very well. When I was at a stop you could smell the hot engine, and, at the time the burping coolant. I added a bit of foam window seal along the top of the rubber gasket and that ended the odor. It won't fix an exhaust leak but does keep the aromas out of the cab if they are coming in through the ac/vent system.
Old May 15, 2010 | 06:37 PM
gearloose1's Avatar
gearloose1
Check to see if there has been a CCV reroute and if so did they just disconnect the hose and let it exhaust in the engine compartment?
If not, check CCV system for leaks.
Old May 15, 2010 | 10:15 PM
wirthmoor's Avatar
wirthmoor
My 03 had identical symptoms - turned out to be a slight crack in the y pipe that was hard to find.
Old May 16, 2010 | 01:11 AM
gearloose1's Avatar
gearloose1
How was the Y pipe crack repaired?
Old May 16, 2010 | 07:18 AM
4604x4's Avatar
4604x4
mine was replaced with the cab off while getting studs & gaskets
Old May 17, 2010 | 11:47 PM
BEAR_34's Avatar
BEAR_34
the ccv system looks like it could be the culprit of the fumes in the cab. Besides re-routing the CCV, are there any other easier fixes...such as SeaFoam??
