Scan Guage User's
Old May 14, 2010 | 06:15 PM
rcorcich's Avatar
rcorcich
Scan Guage User's
Do any of you that watch ECT use a X-guage command for it, if so please post all values. Or do you use the canned ECT that comes pre programmed,
Thanks Rich
Old May 14, 2010 | 06:19 PM
69cj's Avatar
69cj
I use ect canned and eot X gauge.
william_04_x's Avatar
william_04_x
I've used the canned water temp for a few years now. Never even looked for another code for it..
Old May 14, 2010 | 06:40 PM
rcorcich's Avatar
rcorcich
i'm using the canned also , but i run a non towing temp of about 175 deg. seems low compared to the 193 i'm hearing from other members
Old May 14, 2010 | 06:51 PM
69cj's Avatar
69cj
Sounds like a stuck t-stat or wrong formula in the program.
Old May 14, 2010 | 07:36 PM
rcorcich's Avatar
rcorcich
using canned formula, just had the oil cooler rebuilt w/kit and new egr cooler and cooling system flushed and new ect sensor under warranty, I think i'll repace the t-stat myself.and see if it fixes it.
Old May 14, 2010 | 08:11 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
I use the canned ECT, and Xgauge EOT. Morning check, ECT 57f EOT 57f. Just for fun, the other night I plugged in the block heater.
Ambient air 51f, ECT 137f - EOT 127f
Old May 14, 2010 | 08:29 PM
rcorcich's Avatar
rcorcich
just ordered a housing, t-stat and gasket .We'll see soon enough .
thanks all
Rich
Old May 15, 2010 | 08:05 AM
69cj's Avatar
69cj
thanks all
Rich
Why a housing? Do you have that much corrosion?
Old May 15, 2010 | 09:10 AM
rcorcich's Avatar
rcorcich
I wanted to replace the thermostat a while back because I suspected then , and when I had it apart I couldn't get the thermostat out of the housing and was afraid of damaging it and wouldn't be able to use the truck until I replaced it, so I just put it all back together.Now after all the other work is done and still not seeing proper temps, i'm going back after the thermostat in one clean sweep so it's easy and painless, plus my buddies a Blue Oval Parts Guy...
No corrosion wasn't bad but the damn thing was just stuck in there?? and i didn't want to beat on it.
Old May 15, 2010 | 10:03 AM
69cj's Avatar
69cj
Place the housing in a vice, push down on the t-stat and turn. Like a bayonet connector.
Old May 15, 2010 | 08:12 PM
rcorcich's Avatar
rcorcich
Thanks,...
I'll give it a try ,
anyone with a dually running 4.10's lookin for average oil temps with out towing
Thanks
Old May 20, 2010 | 08:52 PM
rcorcich's Avatar
rcorcich
replaced thermostat and now reads 193 to to 195 deg. under normal temps ,fixed...
anyone have any ideas why eot woud read 202 to 209 ?
Dealer rebuilt oil cooler , replaced egr cooler, flushed cooling system , new eot, and ect sensor,and did oil change and filter w/ dino.What else would cause a higher eot reading ? Any Idea's...
Thanks Rich
