Sponsored by: Real Truck
A/C information
Old May 14, 2010 | 06:08 PM
powerstroke_n's Avatar
powerstroke_n
A/C information
I've got a 00 CC Dually and was wondering if anyone tell me what controls the engaging and releasing of A/C clutch. Could it be one of the relays in the PDB if so which one. I just pulled a vacuum on the system last weekend and filled it back up. The problem I'm having is when I first turn it on it cools fine but after about 15-20 minutes the clutch kicks out. I've noticed when it does this I can stop somewhere for a bit if I'm out and about get back in and it works but not but for about 5-10 minutes. I'm just wondering if it's a relay thats getting hot for some reason and dropping out. If not a relay what other reason could it be. Happens like this every time. Any info anyone could give would be appreciated.
Old May 15, 2010 | 12:25 PM
powerstroke_n
Thanks to SpringerPop on this info. Worked great.
You have a classic case of the air gap in your compressor having worn too wide.
Try this to test:
Turn on the A/C and run it until the clutch won't re-engage. Be REAL CAREFUL now! Take a plastic screwdriver handle and "tap" the end of the (not spinning) clutch. Does it immediately engage and operate normally until it next cycles off, and then won't re-engage on its own?
If so:
Get out your feeler gauges, or your calibrated eyeballs, and determine that the air gap is about .050" to .060" (fifty or sixty thousandths). That's too much! It's supposed to be around .030. But wait! There's no need to replace the compressor and have to re-charge the system. There's a "dirt-cheap" fix!
See the little bolt right in the middle of the compressor shaft? Take it out. You won't be letting any Freon out. Pull the clutch plate straight out. There is one or more "shims" that look like small washers in there, either on the end of the shaft or down in the hole that fits on the shaft. Take off about .030" worth of them and reassemble. Go ahead, use a little blue (NOT green!) Loctite on the bolt as insurance.
Make sure you now have at least .025" of gap. Start the engine and check to insure your problem is gone.
That's all there is to it.
Pop
Old Jun 26, 2010 | 03:59 PM
bentcipher's Avatar
bentcipher
Having the same issue except mine cuts out like in first 30 seconds of the truck being on ('01 5.4L). The compressor clutch will disengage and A/C just blows warm air. I tried the "tapping" on the compressor, then just replaced it altogether, evac-refill system, jumping low pressure switch harness yields no results...
But get this... if I ground A/C clutch relay the compressor kicks on and blows cold... wtf???
Old Jun 27, 2010 | 10:24 PM
bentcipher's Avatar
bentcipher
BTW, fixed my issue by taking care of a check engine light throwing code P0355... bad coil on cylinder 5.... apparently that would cause your PCM to shut off your compressor...
Go figure...
hoytenticer
1983 - 2012 Ranger & B-Series
Aug 6, 2024 12:13 PM
bentcipher
Jul 1, 2018 10:20 AM
Soodude
Jul 18, 2011 07:47 AM
psull
Jun 28, 2008 12:14 PM
Tony1974
Jun 14, 2005 09:48 AM
