Injector Replacement
Old May 17, 2010 | 07:45 PM
npccpartsman's Avatar
npccpartsman
Originally Posted by beemr
Where can I locate wiring diagrams (schematics) of the relays?
Engine wiring diagram can be located in the 6.0 tech folder
Old May 19, 2010 | 07:42 AM
jwheatley20's Avatar
jwheatley20
alrighty, back on topic.
Step one says to remove valve cover. Easy enough. But there is too much crap in the way. Ive taken off the aluminum boost tube, air intake, and coolant bottle. Drivers side looks like I can take it off now. Passenger side looks like I need to take the A/C apparattus off in the corner of the firewall. Am I right? If so, Ive taken (5) 8mm bolts(for plastic) out that look like it holds it in, but it still wont budge. Any tips?
Old May 19, 2010 | 09:35 AM
rickatic's Avatar
rickatic
You should not have to remove the AC box to remove the valve cover and the HP fuel rail.
Old May 19, 2010 | 03:21 PM
m-chan68's Avatar
m-chan68
I agree. The A/C evaporator housing DOES NOT need to be removed to access the passenger side valve cover. A short 12mm racheting type wrench is all that's needed to access those two bolts.
Old May 19, 2010 | 03:28 PM
m-chan68's Avatar
m-chan68
Also, a chrome 19mm 12 point socket will be needed to push all eight injector connectors through the rocker arm carrier, in absence of the Rotunda tool. This of course, is after you've removed all nine TX-30 bolts securing each rail over the top of the injectors. After that, simply remove the TX-40 injector hold-down bolts and the injector will come out.
Old May 19, 2010 | 03:40 PM
jwheatley20
ok thanks guys. I'm gonna go out and try that. It looks like the Ford mechanic who did my head gasket replacement stripped the 10mm hold down washer type bolts on the silver module on the drivers side. Its a biotch.....
Old May 19, 2010 | 04:28 PM
m-chan68's Avatar
m-chan68
If you are referring to the four 10mm nuts that secure the FICM mounting brackets to the valve cover, use the open end of a 12mm wrench to hold the valve cover stud while loosening the said 10mm nuts to prevent the stud from turning as well. It's very common for these nuts to be overtightened.
Old May 19, 2010 | 11:09 PM
jwheatley20
Thanks for the heads up. Hopefully this job doesn't turn out to be a nightmare.
Old May 20, 2010 | 07:12 AM
TurnerBioDiesel's Avatar
TurnerBioDiesel
It isnt all that bad, The nightmare part is when the injectors you bought dont work and have to take it all apart 3 times. Bought one from ford, didnt work, had to replace. Bought 4 from Pensicola diesel, 1 didnt work, put everything back together then the tip split on another. Very, very frusterating. I have not had any luck with injectors.
Old May 20, 2010 | 07:53 AM
jwheatley20
valve cover is off. 9 T-30 bolts are out. How do I get the rail out on the passenger side? There is a tube on the back of the rail going down into the head. And the stupid A/C **** is keeping the rail from being able to pull out. Any tips on this?
Old May 20, 2010 | 08:16 AM
jwheatley20
Sorry for so many posts guys. I just really don't wanna mess anything up.
This is the oil rail thing. In the back of the picture u can see the tube going down into the head. This is whats keeping me from taking this thing off.
I have it turned slightly so now I can see the injectors. Where does the 19mm socket go?
Old May 20, 2010 | 04:18 PM
jwheatley20
Ok I got the injector out ur looking in the last picture. But I cant get the rest because the rail still wont come off.
Old May 20, 2010 | 06:20 PM
  #28
cheezit's Avatar
cheezit
you need to remove the stand pipe (tube thingy) from the oil rail first. there is a all head plug in the top of the rail. remove that lift out tube then remove oil rail.
Old May 20, 2010 | 07:46 PM
  #29
jwheatley20
Is the tube attatched to the plug or do I need to hold the pipe to keep it from falling down.
Old May 20, 2010 | 08:13 PM
  #30
cheezit's Avatar
cheezit
soem times the stand pipe gets stuck together but it is 2 parts. you will need to seperate them to remove it. the tube wont fall in.. the base of the tube is feed from the branch tube.
