Have you looked under the hood at the throttle cable system? A lot of the aftermarket cruise actuators were electric servo motors, not the vacuum type like the factory liked to use.
If you can find out the setup, even if it's vacuum, I would compress the actuator as much as it will go, and see if the throttle is wide open. It may just be a matter of a linkage adjustment, if the cruise is fully open, but the throttle is not.
Follow the cable from the throttle, and you'll find the actuator.
Vacuum cruise control is kinda lame unless you have a fair bit of extra power. Asyou hit the throttle, you have less vacuum. I had a Subaru turbo that would produce boost at highway speeds, needless to say the cruise didn't work hardly at all.
Thanks to everyone who posted. I've found the problem....
The cable from the actuator was damaged; the actuator was next to the driver-side battery; the first 7 inches of cable from the actuator went under the battery plate and was damaged by battery acid; the jacket of the cable was totally gone so when the actuator pulled the whole cable moved.
I've since opened the actuator, cut the fouled end & am re-attaching the cable into the unit.
