Need a Little Help in Removing the Valve Covers
It's a 1999 F150 with a 5.4
Is there a trick to taking off the left valve cover without messing with the EGR tube that goes down to the exhaust manifold? The fittings look very rusty & crusty and I really don't want touch them if I don't have to.
The right side looks straight forward but something is holding the injector/coil harness in the back by the firewall. I can't see to good back there but something is keeping the harness from being pushed out of the way. Whats there?
i sprayed the EGR tube fitting with penetrant a couple times while working on other parts. I used a 10 inch pipe wrench to grab the fitting tight instead of an open end wrench. i held it tight and smacked it several times with a 2 pound hammer to get the advantage of shock load. It gave up pretty easy after that. Wire brush and antisieze prior to reassembly.
