Dummy Gas Door
Old May 14, 2010 | 12:41 AM
FX5's Avatar
FX5
Dummy Gas Door
I'm sure someone has ran into this. Your truck has a rear tank, you replace the bed of a truck that has a front tank but no rear tank. The bed however does have a "dummy" rear tank door. Is there anyway to convert the "dummy" door into a functional door so you can keep your rear tank?
Old May 14, 2010 | 11:19 AM
mark a.'s Avatar
mark a.
I'm not quite getting the ? If you are asking if a dummy door can be made into a opening door the answer is no. Opening doors would be a dime a dozen in junk yards and will bolt right into where the dummy door was.
Old May 14, 2010 | 05:05 PM
FX5's Avatar
FX5
Alright, if I can bolt an opening door into where a dummy door was, that'll work great. Just didn't wanna buy a front tank bed with a dummy rear door and not be able to make it work with my rear tank truck.
Old May 14, 2010 | 05:07 PM
Tees77f150's Avatar
Tees77f150
I am sure you will be able to make that work.
