Trans swap
Old May 13, 2010 | 10:50 PM
c27schmidt's Avatar
c27schmidt
Trans swap
I was wondering if anyone new any way or any transmissions that bolt up to the FE blocks that are 5 speed mauals it anyone knows of any or any transmission that is has more than 4 gears to it I could use some help.
thanks
Old May 13, 2010 | 11:17 PM
85e150's Avatar
85e150
Clark transmissions from medium duty trucks will bolt on if you get the right bell and have machine work done on the input shaft. Probably need cross member and DS work. Need a clutch disc for that input shaft too.
NV4500 will bolt up with an adaptor, requires cross member work and probably DS work.
This is a common question. Gas got you down? Keep in mind, a 20% increase in mpg isn't going to pay for this in any short amount of time.
This thread discusses the options, and contains links to other threads with more specific information and to a company with the adaptor and info on the NV4500:
https://www.ford-trucks.com/forums/9...-fe-360-a.html
What trans and axle ratio do you have now? What type of rear axle do you have? (9", Dana?) 4x4 or 4x2?
Old May 13, 2010 | 11:25 PM
c27schmidt's Avatar
c27schmidt
i have the dana 60 with 4.10's and its 4x4 and c6 tranny
Old May 13, 2010 | 11:55 PM
85e150's Avatar
85e150
Three strikes...
Dana: Not easy to change ratios
4x4: You'd have to do it twice. (or buy and adaptor for your new trans to TC)
C6: You need a flywheel, bell, etc in addition to the gearbox...
I have 4.10s in my truck with 30" tires. Approx 3000 rpm at 65 mph. I feel some of your pain, as I have a 5th gear already, but I see what you're up against.
Your TC married or divorced?
Another option:
Gear Vendors Under/Overdrive Ford 4-Wheel Drive 3-Speed Automatic.
Not cheap, but you don't have a cheap or easy option here yet.
Old May 14, 2010 | 04:41 AM
jowilker's Avatar
jowilker
thanks
Are you thinking another gear might get you better mpgs??
John
Old May 14, 2010 | 09:53 AM
c27schmidt's Avatar
c27schmidt
no its just with the three speed tranny it raps like 3500 when im going 55 and id just like it to have a lil more top end speed at a little lower rpm
Old May 14, 2010 | 09:55 AM
c27schmidt's Avatar
c27schmidt
Yeah and since mines the high boy its got the factory 4 inch lift and i have 33's
Old May 14, 2010 | 09:57 AM
c27schmidt's Avatar
c27schmidt
and its a divorced tc
Old May 14, 2010 | 02:07 PM
jowilker's Avatar
jowilker
All non overdrive trannys have a 1 to 1 output ratio. 3spd, 10spd doesn't matter. Sounds like you need a lower number rear ratio but since it is a 4wd both ends.
That is not gonna be easy to pull off.
John
