C6 IDENTIFICATION !!!!!!!!!!!!!!!!!!!!
Old May 13, 2010 | 09:56 PM
ol-blu's Avatar
ol-blu
Hey guys got a question for y'all.... I just picked a transmission for my mud truck,and cant figure out a few things.....
There is a vacuum body on the rear right side of the oil pan on the C6, is that for the kick-down???
Also, there's two linkages on the left side of the transmission, I'm assuming the one is for the gear selector, but What would the other one be for???
Thanks for the help guys!!!
Old May 14, 2010 | 03:49 AM
Lazy K's Avatar
Lazy K
The vacuum modulator is connected to engine manifold and controls the points when the transmission will shift.
One of the levers on the side is connected to the shifter in the cab and selects P,R,D and so on. The other lever is the kickdown lever and connects to the throttle linkage using a rod or cable.
Old May 14, 2010 | 09:37 AM
White 97 xlt's Avatar
White 97 xlt
^^^ What he said!!
Old May 14, 2010 | 06:40 PM
ol-blu's Avatar
ol-blu
So.... If I was going to run a fully manual valve body on the C6, the Vacuum Diaphram on the right side would not be needed and the kickdown lever on the left as well,...? Just curious as how far the kickdown lever on the left side will move.... I try to move it by hand and it only will move about 3/4 of an inch or so..... what would be the cause of that???
Thanks guys !!!
Old May 15, 2010 | 05:38 AM
tjc transport's Avatar
tjc transport
i ain't rite
the downshift lever only moves about 3/4 inch, so it sounds like it is ok
Roelito78
42
Nov 6, 2010 07:02 PM
zrxlover
Oct 1, 2009 04:23 PM
mattsf-100
May 1, 2007 06:30 AM
bbussman40
Sep 23, 2006 09:37 PM
JIMY
Nov 16, 2004 08:12 PM
