Sponsored by: Real Truck
Front Rotor Question
Old May 13, 2010 | 08:28 PM
M88's Avatar
M88
Our 2001 F350 SRW 4x4 nees front rotors NOW. They are just in real rough shape.
Looking online I find two different types of rotors listed; the type where the rotor is just a rotor and the type where it is just a hub.
Which one does this truck use?
To me, it looks like it's just a rotor and to change it I would take off the caliper bracket and replace the rotor.
Any suggestions?
Old May 13, 2010 | 08:39 PM
Rugby3's Avatar
Rugby3
It's just a rotor. The hub is separate.
Old May 14, 2010 | 04:43 PM
StevieD6262's Avatar
StevieD6262
Separate Rotor. I just replaced mine. The rotor cost about $110 at NAPA
Old May 14, 2010 | 05:04 PM
BigPigDaddy's Avatar
BigPigDaddy
You are correct!
Old May 15, 2010 | 12:04 AM
wallz's Avatar
wallz
Here ya go, even torque specs and pictures to make it easier for ya. Welcome to guzzle's Powerslot/Hawk pads brake Maintenance Web Page
Old May 16, 2010 | 11:18 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
4wd uses the top hat design that slides right on. 2wd trucks use rotors that are connected to the spindle, and are a PITA to change, those are probably the other kind you're seeing
Old Jul 19, 2010 | 02:39 PM
white dually's Avatar
white dually
I have a 2002 Super Duty 4WD dually. Does this truck have the top hat style? I know there is a spacer attached to the front part of the rotor assembly. Just don't know if I have to pull the bearings in order to replace the front rotors.
Old Jul 20, 2010 | 08:33 PM
texastech_diesel
Token Redneck
Rotor setup should be the same. I assume you just unbolt the spacer and then it's like a SRW truck, just with shorter studs. But I haven't torn a dually apart for a brake job, so I'm basing this on one parts diagram for a 550 that doesn't show the rotor, but yes, it should be the same.
