Front Left Tire Smoking
Old May 13, 2010 | 12:56 PM
wolfieum16's Avatar
wolfieum16
I have a 2004 with roughly 75k miles. It was raining, and I pulled into a gas station. I got out and smelled an awful smell, then looked at my front left tire and smoke was coming out through the tire. What could this be? I am taking it into the shop to get the rear differential fixed next week, can I drive it to there and have them look at it? or should i have it towed? Thanks for the help.
Old May 13, 2010 | 01:06 PM
hivoltj's Avatar
hivoltj
You mean coming out between the wheel spokes? I'd say your brakes are locked up on that wheel. I wouldn't drive it until you get it fixed. How far is the shop?
Old May 13, 2010 | 01:24 PM
wolfieum16's Avatar
wolfieum16
yes coming out between the wheel spokes
Old May 13, 2010 | 03:33 PM
n5926g's Avatar
n5926g
Sounds like you have a locked up brake caliper.If you continue to drive it,youll wreck the rotor(if its not already toast).IF you must drive it,make it a REALLY short trip.
Old May 13, 2010 | 04:38 PM
Ryan50hrl's Avatar
Ryan50hrl
You've already probably baked your front rotor and caliper....along with your pads....plan on a whole front brake job.....and potentially a bearing...
Old May 13, 2010 | 05:22 PM
1bad67sbf's Avatar
1bad67sbf
if the shops close than drive it maybe stop and check every now and then but if you do have to get it towed you will be closer to the shop.
Old May 13, 2010 | 06:10 PM
powersmoked's Avatar
powersmoked
I agree. it is probably the caliper frozen. Pull the tire off and look at the setup there are 2 pins that the caliper slides on. see if yo can free them up and see if you can free up the caliper , whack it with a rubber mallet..
NinthGenF-SeriesOBS
Oct 12, 2016 05:22 AM
Lowpala
19
Oct 31, 2015 01:24 AM
dynarider33
Aug 28, 2014 07:52 PM
rog2867
Jul 2, 2009 03:40 PM
NascarNut
Appearance & Dress-Up
27
Feb 24, 2005 09:58 PM
