Best fluids for the drivetrain?
Trans (4 speed manual)
Front diff
Rear diff
Transfer
1980 F150
What is the absolute top notch oil I can run in each of those?
I don't want to start a bunch of threads for every bug, there's alot. So here's a couple other questions if you guys don't mind
- I'm getting compression in the crankcase? Steam (looks like) coming from breather and dipstick gets unseated from the tube while running and steam(?) from there as well. Bubbles in the oil. Oil looks healthy otherwise, not milky, no white smoke or sweet smell from the exhaust.
- Heat tube for the carb is broke in half, is there a way to repair it or if there's a backyard remedy/part #?
- The front end appears to be sagging, top of tires are tipped in. New springs or small lift springs.. or? It's bad enough that when sitting idle and turning the wheel the whole front of the truck lifts according to which direction I turn. Turn left, left side lifts/right drops and vise versa.
- The vacuum advance on the distributor doesn't look like it's working as it should, when I throttle up sometimes it advances, others not and very jumpy. I think this may be playing a big role in the sporadic performance I've been experiencing.
I know that's alot.. sorry lol. I want to have her back tip top. Still learning alot about the mechanics of the truck, very different than anything I've ever owned or worked on.
Thanks so much
Gear oil smells horrid when "fresh". Depending on environment and usage,it is best to purchase a Chilton's or Hayne's repair manual for specifics.
2)- I'm getting compression in the crankcase?
Is it "condensation"?
3)- Heat tube for the carb is broke in half, is there a way to repair it or if there's a backyard remedy/part #?
Dorman offers a replacement...in the "Help" display at the local parts store or on-line.
4)- The front end appears to be sagging, top of tires are tipped in.
Has it had a front-end alignment?
5)- The vacuum advance on the distributor doesn't look like it's working as it should,
Vacuum lines good?
In your "signature"....it is a good idea to list the specifics of your truck...
i.e. : 1980 F100 300 2wd 4spd. manual styleside shortbed
This gives folks an idea of what you have and how to answer questions.
Also...look through the stickys at the header of the Bullnose forum for a lot of helpful threads.
Vacuum lines good?
2. Not sure? I was thinking compression because it is actually blowing the dip stick out of the tube. Push it back in and it pops right back out shortly after. I've only noticed this "steam" on cold starts, so I suppose condensation could be a culprit, I will have to check it while it's hot. And to note, it is also blowing a bit of oil out of the breather as well.
3. Awesome, thank you! Will have to shop around. O'Reillys didn't have anything at their store.
4. To my knowledge, no it hasn't been aligned since I've owned it anyways. For a 4x4 it seems like the front end is riding low. When I jack the front up, visually the camber seems to correct itself prior to the wheels coming off the ground. It's quite noticeable looking head on at the truck, that the tires are equally tipped in, as if it is sagging pretty bad. Same type of look you'd find on a lowered vehicle without an alignment done.
5. Yes, I replaced the vacuum lines to the booster and dizzy advance.
I'll figure out how to do the signature thing, meanwhile;
1980 F150 300 4x4 4 speed manual styleside long bed 3.55 gears carter carb ds2 long tube headers 31x10.5 15 tires. Other than that I'm not sure what else is going on with it, the PO was the original owner bought new in late 79, he said he rebuilt the engine and did some work to it, exactly what who knows. Visually it's been hacked up, vacuum stuff blocked off EGR deleted dead wires hanging everywhere etc.. and it's got a 110v power wire with grounded plug coming out of the block.. it was ran through the grill when I got it. Can't say I've ever seen that before.
Since I've found this site, after work I've pretty much been glued here reading and learning as much as I can. To the point that it's a little overwhelming haha.
The way you described it with the gray paint and black accents, imo the black wheels would look much better. Atleast what I'm picturing in my head. I just got some new tires (31x10.5 15s) fairly aggressive tread from tireman for $580 installed. Not a bad deal at all. Also came with a 3 year blowout/leak warranty.
May explain the need for an alignment...just wondering
It sat the same way before getting the new tires. And actually the old ones werent wore down, just had flat spots from sitting so long.
The reason I'm leaning away from an alignment as far as the camber goes, it's off bad enough there wouldn't be enough adjustment to get them standing up right and pics I've seen of other factory 4x4s, they appear to sit quite a bit higher in the front end. If I had to guess I'd say 1.5 - 2".
2) check not only the pcv valve, but the tube and port below the carb for blockage.
It could be that the rings are stuck or shot but having good extraction can only help the situation.
4) check the pivot bushings where the beams attach to the frame. These will make your camber problems worse.
4a) jack the truck up from the frame and measure the unladen height of the spring. This will give you some idea of how much it's sacked.
5) Crane cams makes a replacement vacuum advance canister. Check the rest of the distributor for slop before throwing money away. You might be better off buying a whole rebuilt distributor, if you find the drive gear or shaft bushings are worn
Could you elaborate on the slop on the distributor? As far as what I'm looking for.
Thanks for the tips man will definitley check on that stuff in the morning!
If it has an iron case (New Process) use gear oil, if it's aluminum/magnesium use atf.
You don't want or need LS fluid unless you have functional clutches in your rear axle.
You REALLY don't want a GL-5 fluid either.
Chlorine EP additiives will attack the brass synchros in your gearbox.
You can Google 'GL-4 gearbox oil' for explanations of what it does.
"The absolute top notch fluid you could use" is going to be something like Amsoil or RedLine fully synthetic gearbox oil.
At around $35 a quart it might be a much for your budget.
I suggest you turn your engine to TDC #1 and remove the distributor.
Inspect the gear on the bottom for wear and then try and wiggle it side to side.
Any discernable play is reason to get a new/rebuilt dizzy instead of trying to "fix" one that is worn beyond repair.
On my way home from work today the truck ran better than it ever has, wierd. Felt like I had an extra 50 hp, no hesitation or surging. It was a bit warmer today and always runs better than when its cold. Leaving a traffic light when i hit 3Rd gear at about 1/4 throttle the back end went sideways, thats never happened before. Road was damp but even still.
Checked the distributor and actually looks pretty recently replaced, but the advance looks much older.. like maybe the PO pieced it together. I wish it would run like that all the time! Gas needle barley budged, typically I'd use about 1/8th of a tank. Especially on the highway running 65 mph (speedo says 60 but have 31" tires).
Use Mercon-V in the transfer case.
Here's the advance kit for DSII distributors:
http://www.amazon.com/Crane-Cams-99607-1-Adjustable-Advance/dp/B000CCFYL6
Regarding the wheel lean - the coil springs on these trucks all get soft with age & allow the front of the truck to drop, tipping the wheels in at the top; this is probably your problem......they aren't expensive to replace.
I would just get stock replacements for a DD. Some owners have used heavier springs to lift the front, but this gives a harder ride, & leans the wheels outwards at the top.
I replaced mine (from Rockauto) & it made a big difference to how the truck steered, as well as bringing the wheels back to vertical.
