Cruise Control
Old May 13, 2010 | 12:40 PM
codyfeeback's Avatar
codyfeeback
Cruise Control
I recently swapped transmissions with a friend of mine. I have a 2003 F350 lariat crew cab long box 7.3 powerstroke. It had an automatic i swapped my buddy for the manual he had in his 2003 F350 XLT Super cab 7.3 powerstroke. During this process we swapped computers, steering colums, dash, and dash wiring harness. I also had to run a hot wire from the starter to the clutch saftey switch so it would start. The problem i have now is that the cruise control does not work! I took it to the ford dealer and they told me it was the clock spring, well i replaced that and it did not work. Anybody out there got any ideas it would help a bunch cause we are at a standstill. By the way the truck runs great actually even better than it did with the automatic.
Thanks
Old May 13, 2010 | 12:54 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE.
Man, you guys sure did a heck of a lot of work. Why didn't you just trade trucks? . Check the pressure sensor on the brake master cylinder. If that goes out, the cruise will not work.
Old May 13, 2010 | 01:23 PM
Shake-N-Bake's Avatar
Shake-N-Bake
You said you had to run a hot wire to the starter for the clutch safety switch....is that how your friend's truck was wired originally?
On manual trans vehicles, isn't there also a cruise disable switch on the clutch pedal as well as the brake?
03_PSD's Avatar
03_PSD
That is on big swap, you got any pics?
Old May 13, 2010 | 01:34 PM
codyfeeback
Sorry no pics dont wanna remember it was a headache and still is as you can imagine.
Old May 13, 2010 | 01:37 PM
codyfeeback
Originally Posted by miller_feed
Welcome to FTE.
well we would have swapped trucks but i wanted to keep my crew cab plus mine is in way better shape.
Old May 13, 2010 | 01:40 PM
ron's power stroke's Avatar
ron's power stroke
just chatting with a guy that did this over on PSN..he changed out the wire harness for the trans that had everything needed..never did ask about the crues...you could PM him...he is one of a dozen that has done this over there...there pix for you picture lovers..
Auto to Manual Converstion - Powerstroke Nation
IsaLandr
Dec 13, 2014 12:48 AM
dbdbb
Nov 13, 2014 09:16 PM
DieselJerry
Nov 26, 2012 10:23 PM
vic_crazy87
Electrical Systems/Wiring
Sep 10, 2007 08:21 PM
