F350 extra cab?
Old May 12, 2010 | 08:16 PM
kupiec20's Avatar
kupiec20
F350 extra cab?
is there such a thing? if not why!
Old May 12, 2010 | 08:25 PM
foxracing0934's Avatar
foxracing0934
I have seen one, but I think that it was only available for a year or two and only in a 2wd possibly a dually. There were a lot of things that the truck had to be in order to get one.
Old May 12, 2010 | 09:07 PM
JamesHajek's Avatar
JamesHajek
I dont think ive ever seen an OBS ext cab 350...
Old May 12, 2010 | 09:15 PM
fordpride's Avatar
fordpride
I've only seen them in a 2X4 dually
Old May 13, 2010 | 06:22 AM
kupiec20's Avatar
kupiec20
so what was the reason for not making SRW F350?
im looking for a xtra cab but im not a big fan of the front end.
is that front end really that bad?
Old May 13, 2010 | 11:13 AM
Brown Falcon's Avatar
Brown Falcon
The dana 50's aren't bad. If you lift them you need to make sure the center pivot is moved down along with the lift.
You can't always swap in the Dana 60
Old May 13, 2010 | 11:33 AM
superduty4x4's Avatar
superduty4x4
There are F350 ex cabs out there. All the ones I've seen are duallys and Centurion conversions, not factory rigs.
The TTB isn't too bad, I had good luck with them but I never owned a PSD with TTB. If you want an ex cab with a straight axle the D60 swap is real common and not too much work.
Old May 13, 2010 | 11:40 AM
JamesHajek's Avatar
JamesHajek
If the D50 is good enough for c00nhunterJoe, its good enough for me!
Old May 17, 2010 | 11:00 PM
rn360908's Avatar
rn360908
I hate the D50. I had one under my f250. My truck has 4.5 inches of lift and needless to say it started wearing out the outside edge of my 35, 12.50s real bad and thats after I had miss alignment bushing put in, I also had the drop bracket installed for the center pivot. So I just put a KPD 60 under it and got rid of that junk D50. I also had a friend that had to change out the center pivot bushing on his D50 every 2000 miles until he did a D60 swap
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
