4.9 performance
Old May 12, 2010 | 03:53 PM
dean scrooby's Avatar
dean scrooby
4.9 performance
hey guys, i was wondering what the best way to add a bit of power to a 300 would be?
Old May 12, 2010 | 05:41 PM
1bad67sbf's Avatar
1bad67sbf
offy intake w/ around a 450-500 cfm carb, 1.7 chevy 250 rocker arms, efi dual exhaust manifold
Old May 13, 2010 | 05:35 AM
dean scrooby
thanks alot! would that make a sigificant amount of power or nothing to crazy?
Old May 13, 2010 | 06:47 AM
1bad67sbf's Avatar
1bad67sbf
that will make a nice bump in power but nothing crazy. to get big power takes more money (cam, roller rockers, better ignition, head work, ect)
Old May 13, 2010 | 06:53 AM
ctubutis's Avatar
ctubutis
A good forum to look through is the 6-banger one here:
Ford Inline Six, 200, 250, 4.9L / 300 - Ford Truck Enthusiasts Forums
Old May 13, 2010 | 08:15 PM
dean scrooby
thanks for the info!
Old May 13, 2010 | 08:57 PM
mlc8761's Avatar
mlc8761
wow !
Tell me more about 1.7 chevy rocker arms
Old May 13, 2010 | 09:05 PM
1bad67sbf's Avatar
1bad67sbf
stock rockers are 1.6 and chevy 250ci 6 cylinder has 1.7 rockers so they give you more lift on the cheap (without buying a cam)
Old May 13, 2010 | 10:55 PM
300 Buster's Avatar
300 Buster
Dean Scrooby,If you want some good input on 4.9 mods,go to the 6 cylinder forum on here.either start a thread or search the forum,every thing from mild to wild,and welcome aboard!
Old May 14, 2010 | 08:16 AM
mlc8761's Avatar
mlc8761
They bolt right up
So the chevy rocker arms fit on the Ford? with no problems. plug and play?
Old May 14, 2010 | 11:45 AM
300 Buster's Avatar
300 Buster
Better do some checking on that,I think push rod length may be affected.Search sbc rockers on the Inline 6 forum.Lots of info there.
Old May 14, 2010 | 04:09 PM
1bad67sbf's Avatar
1bad67sbf
everyone is right i know some but some of those guys live 300, 6. im more a small block guy that has a 300 in one of my trucks
Old May 14, 2010 | 05:40 PM
dean scrooby
i thank you all again for all the info! what i am trying to do is figure out if i could get some more power out of the 300 or if it would be easier to do a engine swap? i do alot of towing with the truck and work it pretty hard. what engine would you recomend if i were to do a swap? i have a 1984 f150, 4x4, 4 speed.
Old May 14, 2010 | 05:45 PM
1bad67sbf's Avatar
1bad67sbf
they will tell you to keep the 300 or use a 351w. i was going to put a 302 in mine and nobody thought that was a good idea! but i love 302s
Old May 14, 2010 | 08:47 PM
BurninValves's Avatar
BurninValves
I just picked up a 429 for my truck, I was gonna go 351 but the 300 uses a BB bellhousing so i figured what the hell, why not.
