1978 - 1996 Big Bronco
Oil pressure sensor
Old May 12, 2010 | 10:31 AM
Mac88's Avatar
Mac88
Oil pressure sensor
Does anyone know where the oil pressure sensor goes into the motor. Mine is not working and i want to replace it. It's a 95 EB Bronco with the 5.0. Thanks
Old May 12, 2010 | 11:41 AM
mprice's Avatar
mprice
It's screwed into the side of the engine block. It's difficult to see but it's almost straight up from the oil filter. It has a single wire with a press on connector going to it. It helps to have the special socket to get it out.
Old May 12, 2010 | 03:55 PM
theperson10's Avatar
theperson10
Speaking of oil pressure sensors, is it possible to replace the stock one with a more accurate one that will work with the stock gauge?
Old May 12, 2010 | 04:21 PM
Encho's Avatar
Encho
The Southernmost Mod
Basically not, the most accurate oil gauges are mechanical, and actually run a little oil inside a line to measure the pressure, so they won't work with our electrical gauges and sensors.
Old May 12, 2010 | 04:46 PM
khadma's Avatar
khadma
Carpenter Local 745
I have installed electric sending units and OP gauges on my 07 Explorer and 02 F150. There are many threads regarding the operation of stock pressure gauges.
I have a unit (sender and gauge) on order for my 96 Bronco.
Yes, the sending unit on the Bronco is just above the oil filter, it is set pretty deep and it is hard to see.
Old May 12, 2010 | 06:00 PM
b4hntn's Avatar
b4hntn
I removed my sender, screwed in a 1/4 " brass pipe nipple 6" long. Then connected to a good mechanical gauge. I like it.
Old May 12, 2010 | 07:45 PM
Ricky B's Avatar
Ricky B
And if you wanna get even more fancy with the plumbing, you can actually go with a new mechanical gauge AND still use the stock dash gauge.
Like I did........
Old May 12, 2010 | 09:57 PM
khadma's Avatar
khadma
Carpenter Local 745
Like I did........
I use an electrical gauge and keep the stock one functional too.
(I think the 07 Explorer still needs the sender signal)
No matter how you do it, a real oil pressure reading is important.
Old May 12, 2010 | 10:12 PM
Ricky B's Avatar
Ricky B
Yup, cuz the stock gauges (in theory) only need 6-8psi to move. Doesn't mean they're right though-----and if you're on the freeway doing 70 and you happen to look down and see your dash gauge go to Zero, by the time you pull over you're probably gonna be the proud owner of a 500 pound paperweight..........
Old May 12, 2010 | 10:23 PM
greystreak92's Avatar
greystreak92
AMEN! Electronic gauge = glorified "idiot light".
Old May 13, 2010 | 09:03 AM
Encho's Avatar
Encho
Ricky B, how did you do that? the gauges are working sepparately? (that would be my guess).
Old May 13, 2010 | 09:19 AM
Ricky B's Avatar
Ricky B
It took me about an hour to sort it out geometrically, but basically I just went to my local hardware store and bought a bag full of various brass pipe fittings (els, tees, nipples) and made it work. But it did take some playing around. The trick is to make sure you finish up with enough clearance so that you can still get your oil filter wrench on the filter. I'll try to take some pics of it for you later today to give you an idea on what mine looks like if you want........
Old May 13, 2010 | 11:01 AM
Encho's Avatar
Encho
I would like to check those pics.
smh193
1983 - 2012 Ranger & B-Series
Dec 8, 2012 09:59 PM
fordboy300
13
Aug 9, 2012 11:35 AM
rthacker
Aug 24, 2010 08:20 PM
1979f_100
Apr 6, 2003 04:47 PM
davidson07
May 15, 2002 09:58 AM
