1978 - 1996 Big Bronco
A/C question
Old May 8, 2010 | 09:39 PM
hey172's Avatar
hey172
A/C question
I own 1993 bronco XLT and was thinking of upgrading my A/c fan blower
to help get the cooler air to the back faster is there an upgrade out there for that?
Old May 9, 2010 | 06:42 AM
gjnicholas's Avatar
gjnicholas
don't know but sounds like we all need that one. might be eaiser to tap int vents and run vent under seats to back
Old May 9, 2010 | 11:31 AM
greystreak92's Avatar
greystreak92
Remove the top and save the fuel. Better air conditioning and fresher air. Larger blower will most likely draw more electricity anyway. Just my silly little opinion. I never use my a/c even in St. Louis river valley summers.
Old May 9, 2010 | 07:28 PM
b4hntn's Avatar
b4hntn
I would also like more fan but my old alternator has a hard time keeping up with the highest fan speed now.
I do get colder air now at stops with the severe duty fan clutch. It is noisy when engaged but cools better.
Old May 9, 2010 | 08:45 PM
Encho's Avatar
Encho
The Southernmost Mod
Down here A/C is a REQUIREMENT. hmmm, i wonder if closing the top vents will help my A/C. Mine has the bad custom to divert the air there when i push the engine, rings any bells?.
Old May 9, 2010 | 09:14 PM
hey172's Avatar
hey172
mine used to divert the air like that till i fixed the vac prob it was a lil plastic line on the passanger side under the hood
Old May 9, 2010 | 09:16 PM
hey172's Avatar
hey172
I live in the Arkansas River Valley gets fairly humid
Old May 10, 2010 | 08:07 PM
Encho's Avatar
Encho
hey172, i see that little vac hose, it seems to be brittle and in pretty bad shape, could you tell me from were to were i should place the new hose? or in any case, take a pic of yours?.
Old May 10, 2010 | 09:47 PM
hey172's Avatar
hey172
I'll send a pic of mine asap but when i fixed mine there was only a lil bit of the line that was bad so cut the bad away and rehooked the rest .
Old May 11, 2010 | 04:34 AM
b4hntn's Avatar
b4hntn
The white vacuum hose runs from the vacuum motor near the passenger side hood hinge into the wiring harness that goes through the firewall.
Old May 11, 2010 | 12:15 PM
JohnMcD348's Avatar
JohnMcD348
I need to replace the tubing in mine also but it holds well enough for the most part. It only changes to the defrost occasionally but it's obviously chalky and breaking. Mine is a 92 and I've often wondered if there was a fan motor upgrade that would work well in our Broncos. I'm not in Venezuela but in Central Florida. Temps in the 90+ with humidity to match, taking the top off ain't good enough. My charge is good and I still even have a source for the R12 for awhile. It blows cold but just doesn't really put out as well as newer models vehicles. I know I also need to find a headliner to cut down on some of the radiating heat from the roof over my head and get the windows tinted. I'll be tinting the windows myself soon enough. I just need to install the new window sills in first or at the same time.
Is there a source for the original style/size, etc of the tube they used for the A/C vents? Also, does anyone know of a better blower for the newer FSBs?
Old May 11, 2010 | 06:25 PM
hey172's Avatar
hey172
here are the pics i said i would send.
Old May 11, 2010 | 06:47 PM
hey172's Avatar
hey172
the pics of the vacuum line
Old May 11, 2010 | 06:49 PM
hey172's Avatar
hey172
vacuum line
Old May 11, 2010 | 08:45 PM
Encho's Avatar
Encho
Thx, i just found out someone removed the part in the second picture, the vacuum motor someone called it? i guess i need one of those.
