stock horn location
Old May 11, 2010 | 11:09 PM
soooop's Avatar
soooop
Question stock horn location
Hello, could someone tell me the stock location for the horn on a 1964 f100. Thanks
Old May 11, 2010 | 11:17 PM
camperspecial65's Avatar
camperspecial65
all horns are between the grille/upper valance panel area and the radiator core support bolted to the core support in a diagonal fashion. The should be holes already in the support for them.
The hood latch needs to be taken out to get it/them in as its a tight fit getting them inbetween the support and upper valance.
They are aimed downward as installed.
- cs65
Old May 11, 2010 | 11:44 PM
soooop's Avatar
soooop
thanks
I will head out to the garage and take a look. Thankyou
Old May 12, 2010 | 01:56 AM
soooop's Avatar
soooop
Still cant find it.My grill is out, should be easy..?
Old May 12, 2010 | 04:53 AM
camperspecial65
yes it should be..look on the core support and the area around there...a PO may have moved it to another spot...it will have a single blade plug in connector from the wiring harness in the headlight area...its the ONLY single blade plug in up there as well.
- cs65
Old May 12, 2010 | 11:39 AM
soooop's Avatar
soooop
My truck was somewhat of a basket case. No wiring etc. The horn was in a milk crate, like many other parts. i just need to bolt it up,but I dont see the extra hole for its location ?
Old May 12, 2010 | 07:29 PM
soooop's Avatar
soooop
Guess I will drill a hole. Thanks.
Old May 12, 2010 | 07:44 PM
camperspecial65
I just looked at mine...one of the holes used is a fender apron/core support hole...the one is almost directly below the large oblong hole above the fender apron mounting area. there will be at the least a dimple at this location and another approx. 2-3" diagonal from it. On mine , both holes were utilized by the boys in San Jose where it was built 45 years ago and havent moved since. The dimples I noticed on another core support I have inside here. The dimples are plainly felt too.
cs65
Old May 13, 2010 | 03:22 AM
soooop's Avatar
soooop
Thanks. I mounted the horn and relay today and ran some wires. i mounted it behind the core support, just left of the radiator.Looks alright and easy to get to.
Auburn_in
Jan 16, 2013 11:57 AM
YoungFordAddict66
Dec 31, 2009 10:17 PM
Shortlineent
Aug 23, 2009 09:26 PM
RV HAULR
Jan 17, 2007 09:17 PM
ehchvac
Oct 17, 2004 07:55 PM
